Old 11-23-2010, 07:08 PM
stainless stainless is offline
Default monitoring
as I'm about to make the plunge and commit to a new 8 core Mac, before I also commit to PT9.0 I figured i should ASK first before buying, rather than re-experience the disappointment of buying a Control 24 only to find out it wasn't close to an analog board when it came to signal routing... (I have since sold it and now have a Euphonix MC control/mix) which i knew upfront had zero signal routing capabilities
With the addition of ADC- can i truly utilize all analog outputs without latency?
I save plug-ins for mixing, but while recording I want to have the ability to send the bussed drum 'mix' to one output, keyboards, to another bass, etc, so i can utilize a monitor mixer to give the players individual headphone mixes (we prefer the "live" approach for the initial scratch/tracks)... never know when the chemistry is there and things just come together
DOES 9.0 ALLOW ME TO DO THIS?????
the latency in 8.0LE assigning duplicate tracks to analog 3 - etc makes it unusable
I suppose one work-around would be to go back to an analog mixer, which has it's merits, especially as i still record to tape... but I don't have the luxury of space to have both control surface and analog mixer (I'd want a 32/8/4 at a minimum)
so..... does 9.0 deliver this?
Avid?
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc
Old 11-23-2010, 07:15 PM
getz76 getz76 is offline
Default Re: monitoring
ADC is a mixing tool. It actually introduces latency (adds latency to the "slowest" track).
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 11-23-2010, 07:32 PM
nst7 nst7 is offline
Maybe I don't understand what you're trying to do, but I'm not sure why you can't already do this in PT8, or any DAW, for that matter. As long as you track at a low buffer setting like 64, there shouldn't be any noticeable latency. Or you can use low latency monitoring if you have to.
Old 11-23-2010, 08:31 PM
Low Latency Monitoring will not work in this situation. The 002/003 LLM is only good for the Output 1/2. If he wants to send different mixes to different talent, that isn't an option.
I agree playback buffer at 64 samples isn't noticeable, but some people I trust disagree.
I believe you need to tap a mixer with a 002/003. Now that Pro Tools 9 is open to other hardware, you might want to consider other interfaces.
Old 11-24-2010, 01:20 PM
so (to be clear) if I don't use LMM and drop to a low buffer (and I assume disable any plug-ins which might get placed on a track... as I understand this would cause some latency) then all outputs should be "in synch"?
but by lowering the buffer aren't I opening myself up to error/session stoppages?
meaning ADC in 9.0 will not help me in this situation?
Old 11-24-2010, 03:11 PM
Zooce Zooce is offline
If you're going to be running an 8-core Mac, buffer at 64 will be just fine. I'm on an iMac Quad core, and recording at 24 48 with 64 buffer; and everything is fine.
**Although, I'm only recording a few tracks at a time, not entire bands. But an 8-core Mac should be able to handle what you want to do with ease.**
Old 11-24-2010, 04:13 PM
I am planning on the 8 core (can't ju$tfy the 12 core)
it's not uncommon for me to record 12 - 14 tracks at a time
[IMG] code is Off
Direct Monitoring VS PT Monitoring therecordinghouse macOS 5 11-23-2013 06:18 PM
Record monitoring level different from Playback monitoring level. sonicflwr macOS 1 03-09-2012 11:05 AM
Monitoring through Rosetta vs Monitoring through 003 Rob0214 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-17-2010 04:02 AM
Auto Input monitoring / Input only monitoring - Alt+K AdamPT8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-09-2010 11:50 AM
Monitoring 5.1 patrick@mailersco.com Pro Tools TDM Systems (Mac) 1 05-23-2001 09:10 AM
