I'm trying to get the optional 17 and 18th inputs on my 002R- however I can't get much signal level into the the track (at least it's not enough to be usable... using the Audio Suite/Gain at +15 dB makes it audible... but not really useful, even though the pre-amp (ART DPS II) is almost clipping
I did find a note in the 002 getting started that (if I understand it) says that if using an optical input, I can't use the rca... however the optical is being used for ADAT in (D8) not SPDIF (and it works fine) SPDIF L/R both show up as inputs and is not checked in the output window- any ideas?
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc |
Are u using an RCA cable?
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' ![]() NO, SHE'S WITH HOBO KEY ' ![]() ('we' must start using pronouns) |
I thought is was an official SPDIF... think that could be it? I read somewhere that short RCA's would work, but otherwise there'd be noise.... no mention of signal loss... I guess it's off to GC to get another cable
It needs to be a SPDIF (Co-axial) cable.. I don't kno if that clears up the low issue, although it should but still, u should hav the correct cable...
Is there not a volume or trim on the Pre that controls the SPDIF signal?
yes, digital output is dimed
I'm off to GC
ProFire 2626: SPDIF COAX & SPDIF OPTICAL Simultaneous success!!! WHAAAA HAPPENED??? | cueball73 | macOS | 0 | 05-22-2012 01:41 PM |
mono like sound from spdif out (GA-EX58-UD3R) to spdif in (Omni ) | chrisdee | Pro Tools HDX & HD Native Systems (Mac) | 9 | 04-02-2012 06:10 AM |
Spdif RCA to Spdif Optical conversion - degradation?? | Hollow Body | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-17-2011 09:21 AM |
Digi 96io - can you mix Optical SPDIF and phono SPDIF? | buckaroo | Pro Tools TDM Systems (Mac) | 1 | 08-24-2009 12:20 PM |
Echo Mia W/ SPDIF also does RCA style SPDIF cause the same crashes as optical?? | Paul_m | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-16-2003 06:41 AM |
