Old 07-22-2007, 07:58 AM
ashraf shater ashraf shater is offline
Default d-command main unit malfunction after upgrade
I have a strange problem ,
after i installed protools 7.3.1 then i installed 7.1.3 cs1 update ,when i add the d-command and I get the message "the d-command unit named D-CMD-F has firmware version v7.0.0.171 which does not match the current version v7.3.0.171 would you like to update firmware in this unit" I choose yes then the same message come for d-command main and i choose yes and after that the d-command fader will work OK but the d-command main will not work correctly ,controls especially the rotary knobs will not work correctly and it when i increase it its led will not lit in correspondence to my rotary movement , and when i restore the old firmware (that come with protools 7.3.1 ) to the units they work fine !!!!!!
can any body help
Ashraf Shater
Old 07-25-2007, 03:09 AM
laki laki is offline
Default Re: d-command main unit malfunction after upgrade
The only advice I would have is to try 7.1.3cs3 instead of cs1
Old 09-17-2007, 08:30 PM
selig selig is offline
I was just searching for the same problem - I'm on 7.3.1cs4 and have just experienced what you describe. Have you found any solution? Did you go back to 7.3.1cs1 with any luck?
Thanks in advance for any helpful feedback!
WTB: Avid D-Command ES, Main unit dicky.chan Buy & Sell 2 08-15-2013 02:48 PM
D-Command main unit, fader pack and X-mon the glass is half empty Buy & Sell 3 06-29-2013 02:41 PM
D-Command main unit and X-mon Stylin' Audio Buy & Sell 4 10-27-2012 03:14 AM
WTB: D-command Main Unit w/XMON mtung Buy & Sell 0 05-16-2012 03:33 PM
D-command main unit won't boot mark linett ICON & C|24 5 08-20-2011 07:35 AM
