#31
Re: OSX 10.7 Lion + PT9
Code:
$ uname -a Darwin imac.local 11.0.0 Darwin Kernel Version 11.0.0: Sat Jun 18 12:56:35 PDT 2011; root:xnu-1699.22.73~1/RELEASE_X86_64 x86_64 $ otool -bash: otool: command not found $ file '/System/Library/Frameworks/Carbon.framework/Versions/A/Carbon' /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon: Mach-O universal binary with 2 architectures /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon (for architecture x86_64): Mach-O 64-bit dynamically linked shared library x86_64 /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon (for architecture i386): Mach-O dynamically linked shared library i386 $ However, Carbon exists and supports both 32-bit and 64-bit on Lion (GM Seed). In my understanding, Lion may run only in 64-bit, but it is simply because Finder.app supports only 64-bit. However, most of other parts including mach_kernel and Carbon still supports 32-bit. Code:
$ file '/System/Library/CoreServices/Finder.app/Contents/MacOS/Finder' /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder: Mach-O 64-bit executable x86_64 $ file /mach_kernel /mach_kernel: Mach-O universal binary with 2 architectures /mach_kernel (for architecture x86_64): Mach-O 64-bit executable x86_64 /mach_kernel (for architecture i386): Mach-O executable i386 $ |
#32
This should clear things up a bit:
http://arstechnica.com/apple/reviews...s-x-10-6.ars/5 I don't believe anything has changed for Lion (OK, you can't run PowerPC applications anymore, and support for some older hardware has been dropped, see http://www.theregister.co.uk/2011/07...int_7_preview/ for more information).
https://lukehoward.com/ |
#33
ONLY FOR UPDATING INFO:
PRO TOOLS 9 WITH LION GOLDEN MASTER 11A511 NOT WORKING, SO THE DEFINITIVE VERSION OF LION COMES IN JULY 19, AND LIKE ALWAYS AVID OVER THE YEARS DONT CARE UNTIL 3 0 4 MONTHS LATER, IM USING PRO TOOLS SINCE VERSION 6 AND ALWAYS THAT APPLE GIVE US A NEW OS AVID/DIGIDESIGN SLOWER THAN A TURTLE... |
#34
After removing WaveSehll-DAE 8.0.dpm, PTHD9 resumed working. This might be Wave's V8r7 compatibility with Lion, rather than PT9 itself. But anyway, it is still far from stable operation on Lion. |
#35
is it feasible to get an update on this -> avid/DigiTechSupt ?!?
#36
On what???
It's a beta OS!!! If you have ever used Pro Tools, you know that it's going to be a long time before there is official support, and AVID WILL NEVER DISCUSS FUTURE PROGRESS OF ANYTHING, EVER. PERIOD. FULL STOP.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
#37
Then it is time for them to hurry up.......... What is the logic in 'they always let us wait so we should be patient again this time too'?
#38
well, it´s better for them to work on the final retail-version. even gold masters can get big changes, then all the work´s for nothing...
Selling: |
#39
if you have a working system why one should be in hurry for an update ?
I mean, I’m using on a system because it works, just for a couple of new features of the operating system I risk to loose my ability to earn money ? If I’m really curious and have the time, I explore it on another hard drive. ....and there are just Developer releases of Lion around, so what you expecting from Avid ? a working pre release of PT to explore an developer release ? .....come on
wolfgang funk marrakech prod www.marrakechprod.com www.linkedin.com/in/marrakechprod https://pro-labs.imdb.com/name/nm3047395 ------------------ Mac Pro 2.8, 8 Core,16 GIG Ram, PT HD 10 - 12. Mac Book Pro 2.6 Retina 16 GIG Ram, Artist Control/MIX. |
#40
what the hell is that matter with you guys? this is how you spend your time? you really WANT TO run an app as complex as PT on a dev copy of an unreleased OS? do you have a single client that would WANT you to do that?
seriously, GO BACK TO WORK, assuming you have any. |
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION | DESVED | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-21-2013 03:18 PM |
lion -> mountain lion question | grant howarth | macOS | 3 | 05-01-2013 01:24 PM |
Lion or Mountain Lion for mid-2009 MBP with PT9 | miezurecords | macOS | 0 | 03-17-2013 12:38 AM |
Would you go from Snow Leopard to Lion (not Mountain Lion) if you could? | EricWillhelm | macOS | 9 | 01-11-2013 10:55 AM |
Macbook Pro+lion+PT9 :-( / iMac+Lion+PT9 = :-) | Pehja | macOS | 12 | 11-08-2011 01:27 PM |
