Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 04-13-2020, 06:31 PM
briaboy briaboy is offline
Default Instrument channel inserts problem
This is a new one on me - loading an instance of a plugin (channel strip) on an Instrument channel. The plugin only works when I insert it at the end/bottom of the chain. I want it at the top of the chain, but when I insert it first, none of the its controls work. Weird. Any thoughts? Oh - this only happens on Instrument channels. Plugin works fine on Audio and Aux channels! Thanks.
Old 04-13-2020, 06:42 PM
Default Re: Instrument channel inserts problem
It has to be after the instrument plugin, or else it has nothing to process.
Scott Gatteño
Yessian
Old 04-14-2020, 06:05 AM
But it's one of the Plugin Alliance consoles (SSL J), which apparently can be inserted across the entire session in the first row, so that it acts like a hardware console.
Old 04-14-2020, 07:35 AM
It will work the same, no matter which slot its in. Probably the demonstration you saw just happened to choose slot A(and maybe they had no instrument tracks in that session). For Instrument tracks, the instrument plugin must be in slot A. Regarding audio tracks, the console plugin can be in any slot as you might want to treat the audio before, or after the SSL strip.
Of course, if for some reason you really WANT all the SSL's in slot A, then you could buss the instrument track's output to an aux track and put the SSL on the aux
Old 04-14-2020, 07:36 AM
That makes sense, sorry for being dumb on this!
Multiple VI inserts on instrument track gdgross Pro Tools 2018 9 07-30-2019 01:24 PM
No channel Inserts??? solomon_love Pro Tools 12 2 02-18-2017 11:53 PM
Instrument inserts not displaying... The Miff Virtual Instruments 3 04-26-2009 06:40 AM
bypass all channel inserts at once tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-31-2008 09:56 AM
How Many Inserts per channel Allowed? musicsup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-22-2005 01:28 PM
