Old 04-02-2020, 02:14 PM
briaboy briaboy is offline
Default Replacing old drum track with new VI
Hi - In Pro Tools (2020.3.0), I'm trying to replace my old drum VI with Superior Drummer. For example, I recorded a kick in the old VI, but when I insert Superior Drummer on the channel, the note triggers the hihats rather than the kick. Is there a way to change this in SD? Some kind of mapping maybe?
Thanks!
bb
Old 04-02-2020, 02:36 PM
rinky rinky is offline
Default Re: Replacing old drum track with new VI
What I do is select all your previous kick notes and transpose/drag to the note that corresponds with SD's kick.
PT Ultimate 2020.5
PT HDX
MacPro 7,1
16 Core
96 GB ram
OS X Catalina 10.15.5
Somehow, musicians are now technicians!
Old 04-02-2020, 02:42 PM
Good idea! I'll give that a go, thanks!
Old 04-02-2020, 04:12 PM
Superior Drummer 2 or 3? Version 2 is not really built to replace sounds of recorded drums. Version 3 is pretty amazing, but you will get better results by watching some tutorials on how to do it. Its actually so capable, that it can replace individual sounds from only a drum mix, as long as its setup correctly
So, if you are on SD 2, I would look at a better tool for the job. SD3 is at the top of my list(but might be more $$$ than you wish to spend) but there is also Slate Trigger, Drumagog and some others that I am not familiar with.
Old 04-02-2020, 04:19 PM
Point is the MIDI notes SD uses are different than many others, so existing grooves need to be modified by transposing MIDI accordingly. PITA but only way.
Old 04-02-2020, 04:29 PM
Thought that might be the case...ok, wish me luck....and thanks!
Old 04-03-2020, 04:07 PM
DonaldM's Avatar
DonaldM DonaldM is offline
I had a similar issue way, way back when with my Yamaha Motif XS8. It has several drum kits and set-ups. So, I recorded the MIDI output of one of their many rhythm arps attached to one of kits. Notes were all over the place. It took me a while to realize that the Motif was using a kit with basically 72 or so different instruments in it. Not your typical set up! Once I figured that out, dragging the notes around to play the same pattern in whatever other drum machine I wanted to use (Kong, maybe? Can't recall), cleared things up!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2019.10
Focusrite Scarlett 8i6
Old 04-03-2020, 04:46 PM
Marsdy Marsdy is offline
Actually no.
In Superior Drummer you can remap notes down to articulation level. What’s more it has mapping presets for many other drum VIs.
Editing MIDI is a can of worms that very often leads to an unusable mess. What if you need to transpose a note to another note that already has data? It gets messy very quickly especially when a lot of articulations are used.
Dave Marsden
UK
Old 04-03-2020, 05:05 PM
That sounds like a better solution
Old 04-04-2020, 08:19 AM
Originally Posted by Marsdy View Post
Actually no.
I think I should just re-record the track, would be quicker and less messy!
Loading in Drum Sounds & replacing oncepureband Tips & Tricks 4 05-17-2011 09:49 AM
Drum Replacing revert979 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 03-29-2009 11:19 AM
Replacing a Kick Drum Sound roainfo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-15-2007 04:06 PM
Replacing Drum Sounds dwman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-11-2006 06:24 PM
Drum sound replacing help. antenna Tips & Tricks 1 04-27-2004 01:15 AM
