Old 06-11-2011, 02:55 PM
kptkarl kptkarl is offline
Default Ctrl+Scrub Wheel issue
Just updated to PT9 from 8.1.1 to 9.0.3. Clean uninstall of 8 and then full 9.02, then 9.0.3 update. OSX 10.6.7. Updated firmware on DCommand. Have not tried with DControl yet.
Annoying workflow issue...
Users here are use to holding Ctrl on the keyboard and using the scrub wheel.
Holding Ctrl+Wheel no longer works smoothly. Scrub light will flash until Ctrl is released, then two seconds later scrub will work. Using the Scrub switch works fine. All other modifier+scrub wheel combinations seem to behave normally.
Trashed prefs, reset DCommand.
Old 06-15-2011, 10:27 AM
druth77 druth77 is offline
Default Re: Ctrl+Scrub Wheel issue
I have notice that ,too.The mark out button works now with the scrub wheele, whith scrub turned on . it follows video ,too.
Old 08-29-2011, 09:59 AM
totoraymond totoraymond is offline
I noticed that too. It's a pity for me and my colleagues. I was using it every minutes when running pro tools 7.4.2
It seems like a bug to me, the D-command's X-mon is 'clicking' when i try to use it...
Hope it will be solved...
Old 10-03-2011, 11:42 AM
Still not fixed in 9.0.5. I have three rooms back on v8 because of this. Paid for the v9 upgrade and cannot use it because of this. When you have users that have worked on these systems for years it is very hard for them to make the adjustment.
Please fix this BUG!
Old 10-11-2011, 04:42 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default
Happened on my system too with my ProControl
9.03 10.6.8
DTS? Have you been able to reproduce this? Would a video help?
Cheers
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Old 10-30-2011, 03:20 PM
Hanswurstlsepp Hanswurstlsepp is offline
Works again in PT10.
Cheers, STeff
MacPro5,1 , 32 Gig Ram, 2xATI Radeon HD 5770, OSX10.13.2  Pro Tools|HDX Ultimate 2018.4.0  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 11-03-2011, 05:51 PM
laki laki is offline
Yep. Confirmed. Working again in 10.
Scrub Wheel or Jog Wheel for PT JaredC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-07-2004 07:01 PM
Scrub wheel recommendations? yin7yang64 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 11-14-2002 12:31 PM
Scrub Wheel Again! Jules ProControl, Control|24, Command|8 183 11-11-2002 09:11 PM
Scrub Wheel - but seriously ! airon ProControl, Control|24, Command|8 15 11-13-2000 07:13 PM
Nifty scrub selector doesn't work on Pro Control scrub wheel ???:eek: Jules ProControl, Control|24, Command|8 10 01-25-2000 11:52 AM
