Convincing trill
I' using Sonovox companion woodwinds. Anyone have a way of making a convincing trill?
Re: Convincing trill
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
+1 for #3 ^^^
I'm not sure about Sonivox but other libraries come with pre-recorded thrills.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Thanks Shan. Works great
Great to hear and thanks for the update!
Shane
I would also try changing velocity between high and low on each note.
Every note should have subtle variations in:
1. timing (as mentioned above don't quantize) 2. velocity (if the library you are using has multiple samples for different velocities, use them!) 3. volume (you can draw in some volume automation curves for each note) 4. pitch (same as volume, you can automate the pitch wheel parameter) The more variation in tone/pitch/timing, the more realistic it will sound. To save time in the future, you can also record your trills and map them into Kontakt or another sampler.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? Last edited by John_Toolbox; 07-09-2018 at 06:41 PM. Reason: Autocorrect makes it read like I am a moron |
To save time in the future, you can also record your trills and map them into Kontakt or another sampler.[/QUOTE]
I'm not vary familiar with Kontakt. Could you explain how to do this? Thanks |
Do you own the full version of kontakt?
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
No. Just the free version
Convincing Drum Roll | rchambrz | Virtual Instruments | 7 | 06-14-2017 01:53 PM |
Need help convincing a club owner to buy DSHOW | soundbobby | VENUE Live Sound Systems | 6 | 06-07-2009 04:46 AM |
Amp Farm for really convincing amped guitars? | Suz-eq | Tips & Tricks | 52 | 02-02-2002 09:37 PM |
I need convincing to get a 2nd hard drive | jim jedlicka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-20-2001 11:28 AM |
