Old 01-29-2020, 02:30 AM
Netmania Netmania is offline
Default Unstable after Update 10.15.3
Sorry to say, but after updating Catalina to 10.15.3 my Pro Tools 2019.12 which worked seamlessly before is very buggy.
I had complete freeze of system, Graphical issues in terms of not showing the Menubar of PT. I know - there has not been a statement from Avid that this will work but - I tried - and I failed. Going back to 10.15.2.
Btw. i have completely reinstalled PT 2019.12 after update Catalina - so that's not an option. I have made a check and found (etrecheck) that PT 2019.12 also installs not compatible Quicktime Components (32bit) to Catalina. Maybe that can cause errors - I don't know. First I´m Musician and not tech guy.
Old 01-29-2020, 06:05 AM
jeam25's Avatar
jeam25 jeam25 is online now
Default Re: Unstable after Update 10.15.3
Hi !
If it worked well on 10.15.2 i don't see a reason while can't be working well on 10.15.3. Keep in mind it has his limitation in Catalina as said by Avid tho. I will install the 10.15.3 in one of my system today and will be back to you with the results. Meanwhile please trash PT preferences and see if that makes a change.
Avid Carbon Interface
Protools Ultimate
Old 02-10-2020, 02:25 PM
Ok. After deleting the prefs and the QuickTime files shown in etrecheck
Pro Tools Quick Time Server 1.0
Quick Time_OPServer 1.0
(all 32bit)
the system is running smoothly again. Since they don't work because of 32bit under Catalina anyhow it's no loss of functionality.
Old 02-10-2020, 02:33 PM
There can be as many 32bit components installed as your storage can hold, because Catalina simply will not run any of those.
I have updated Catalina system for testing purposes (clean install later) and all the non-running 32-bit stuff I have here are marked with do-not-park-here symbol and simply will not launch.
Old 02-10-2020, 02:55 PM
You are right. Catalina has to ignore all 32 bit apps. I had some heavy crashes after updating to 15.3. as I mentioned. The first crashes since I use Macs since 7 Years.
So I ran etrecheck deleted the files and deleted the old prefs and now everything is fine. Thats what's all about.
If everything works we can do what we like to - make music
Peace
10.3.10 unstable audioactive7 Pro Tools 10 17 01-26-2016 10:58 AM
Why is PT so unstable for me? typhy macOS 1 07-31-2012 12:55 PM
PT 9.0.5 - so unstable anackman macOS 4 10-24-2011 01:09 PM
Why is Pro Tools so unstable? Why is support so bad? Update Sandra report added Robert Todd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 02-12-2011 02:29 PM
AAF unstable? jackisdead Post - Surround - Video 2 08-26-2008 03:01 PM
