Splitting midi regions and midi notes
Can somebody please explain the relationship between midi regions and midi notes in PT LE. When you separate a midi region ( in region view) it doesn't separate the midi notes as well. This is totally different to any other DAW I've used eg Reason, Cubase, Ableton. In those progs when split a clip you end up with 2 distinct clips, eg say u split a four bar chord in the middle you end up with 2x 2 bar chords with the midi notes neatly split as well. But to do that in PTLE you need a 2 stage process where you separate the midi notes first ( in notes view) and then split the region in region view. Why does PT behave like this, what is the advantage of it? If you just split the region in region view the midi notes are left extending beyond the first region and the second region has no data at all. Is there a way to split the region and the notes at the same time ? Thanks.
digidesign mini mbox 2: PT v 8.05 LE win 7 pro 64bit 2.6 ghz intel core duo, 4 gig ram |
Re: Splitting midi regions and midi notes
I don't have PT12 but I'm sure it still works the same way. Avid wouldn't change something like that and if they did I'm sure people here would be on it like stink on cheese.
We have been asking for a preference on this since forever. Yes,12 is the same.
It seems incredible you can't do such a simple thing in one go, they could just add a "split region and notes" command to the edit menu, probably 10 mins of a PT developer's time.
Splitting/Stretching Midi Notes | jaynyc | MIDI | 10 | 09-21-2019 09:59 AM |
Splitting MIDI Notes?? | MrWillsi3 | MIDI | 3 | 01-01-2010 05:55 PM |
Disappearing MIDI notes in regions???? | MdotCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-28-2009 12:47 PM |
Splitting Midi Notes | tonedef | MIDI | 10 | 03-25-2006 08:06 AM |
Midi regions/notes question | Ceam | MIDI | 1 | 02-27-2006 12:44 PM |
