Installing PT11 on Mavericks (Old PT10 conflicts?)
I can't seem to find a definitive answer . . .
I have a Mac Pro running Mavericks I mainly work in Logic, but a client wants to use ProTools but Mavericks killed my PT10 — and apparently there's no fix on the horizon I'm willing to upgrade to PT11, but I'm wondering if the "dead" version of PT10 on my computer will cause any problems (PT10 uninstaller won't work in Mavericks) It's my understanding that PT10 and PT 11 are completely exclusive of one another, so I'm thinking I won't have any problems I'm running OSX Mavericks 10.9.2: Can I safely install PT11 along side an existing but non-functioning PT10? Thanks in advance
www.jeffreyleecampbell.com Mac Pro 2.8 GHz Quad 16GB RAM Apogee Rosetta 200/ UA LA-610 Genelec 8030A/7050b McDSP, Waves, Sony, URS, Spectrasonics, BFD, Altiverb |
Re: Installing PT11 on Mavericks (Old PT10 conflicts?)
Yes
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
What version of 10 are/were you on? Depending on the version the co-install is not supported.
What broke? there are a number of people running 10.3.8 on Mavericks
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Hey Craig F
Thanks for reply I was running PT10.3.2 It was opening, but I was trying to configure a session with Apogee Duet for 96k. And PT stopped fully loading. It will still open, but then I get the following message: Could not create a new document because Assertion in"/Volumes/Development/ws.ProTools_10.3.2/AlturaPorts/DFW/MacBuild/../Views/UMenu.MacOS.mm", line 1351 As I said, I live in Logic. Seems like I downloaded a PT10 update, but the installer wouldn't work and I moved on. I've downloaded 10.3.8 update. Guess I'll try to install But I want to ultimately go to PT11 anyway. Just trying to confirm that PT11 will work with a crippled PT10 already on my computer And thanks to clausiii also
For a Co-install you should have 10.3.7+ do to some folder sharing
Had to say w/o knowing what is damaged and you should try the 10 upgrade before 11. 11 then 10 can run into problems do to those shared folders As to the Assertion error most likely holding down the N key when launching Pro Tools to select the Apogee as the interface you are using will probably solve that if not try trashing Pro Tool's Database and Catalog files, there is a helper app to help with that
Thanks!!!!
I'll try your suggestions I'm not really worried about a co-install I have no PT 10 sessions - All Logic I just like to have PT capabilities for clients if needed My main goal is to install a functioning (Mavericks supported) version of PT on my computer. Thanks again for the help
Hey Craig F
IT WORKED!!!! Got 10.3.8. installed and running on Mavericks (And somehow succeeded in configuring a 96K session with Pro Tools Aggregate - using Apogee Duet input/Mac Pro Digital output to Rosetta 200) THANKS FOR ALL THE HELP
This is the second time today I have encountered someone whose working solution to a non-starting PT install was to update to the latest version.
I think it's safe to say that if someone's outdated system is dead in the water, installing the latest version should be one of the first things they try.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
I think you guys should learn to search Avid Knowledgebase and actually read the compatibility documents before you change *anything* in your system configuration. Just a friendly tip from someone who needs to explain these for you on a daily basis...
Committing to PT11 and Mavericks | propower | macOS | 1 | 02-25-2014 02:10 PM |
Is Mavericks now the preferred OS for PT11?? | propower | macOS | 3 | 02-15-2014 12:46 AM |
My Mavericks PT11 exp. | mactools | Pro Tools 11 | 0 | 10-22-2013 08:56 PM |
avid plugins no longer present in PT10 after installing PT11 | Riquier | Pro Tools 11 | 6 | 07-01-2013 07:19 PM |
installing cubase sx 3 on a pro tools rig - any conflicts ? | music project | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-01-2007 05:21 AM |
