macOS Sierra 10.12.6. and multiple USB keyboards and mice
I'm using a MacPro 5.1 with a lot of powered USB hubs (with a lot of synths connected to them) and also 3 sets of USB keyboards and mice.
I use this system for many years with all Mac OS versions since 10.8.5 without any problem. Last week I decided to upgrade an SSD to macOS Sierra 10.12.6 and since then only one keyboard and mouse works, the other ones are dead. Each keyboard also has a LED lamp and when the Mac starts I can see all the LED lamps turn on as normal, but the moment the computer starts to load macOS Sierra 10.12.6 two sets go dead. Once launched I can connect a failing keyboard and mouse to another USB port on a USB hub and it will work again. But after restart macOS Sierra 10.12.6 looses contact again. Restarting with another OS goes fine, everything always works, starting with macOS Sierra 10.12.6 I loose 2 keyboards and mice. I tried a lot of things but I'm starting to run out of ideas. Google tells me it is not uncommon for macOS Sierra 10.12.x to have problems with USB, so maybe it's the OS to blame? Is anyone else experiencing the same problems?
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
Re: macOS Sierra 10.12.6. and multiple USB keyboards and mice
Is there any way you can use traditional 5 pin MIDI to connect your synths to your computer? I use an ancient MOTU MIDI Timepiece AVUSB to do the deed; MOTU has more modern 8 port MIDI interfaces available. This would at least cut down on the USB usage.
I already use a Digidesign MIDI I/0 with 10 MIDI ports, but only for synths that have no USB.
As a matter of fact, switching all my synths off + disconnecting the Digidesign MIDI I/O does not make any difference at all for the keyboards and mice, the problem remains. And when I switch to 10.9.5 all is fine, all keyboards, mice and synths are present and working. Btw, I was able to get 2 keyboards and mice working, but I do not know why. I will keep experimenting...
Just because your system works in Mavericks doesn't guarantee it'll work in Sierra. Is there any real reason you're running Sierra? |
macOS Sierra 10.12.4 | Pedro perez | General Discussion | 1 | 03-27-2017 07:35 PM |
S3L-x, PT 12.6 and macOS Sierra? | HLD | VENUE Live Sound Systems | 0 | 11-01-2016 01:25 PM |
Help: Can multiple (2) windows keyboards and mice work? | StinkyStan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-01-2009 09:30 PM |
are wireless keyboards/ mice solid w/PT? | kindkind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-19-2005 11:32 AM |
Wireless Keyboards and Mice in the Control Room | spicyitaliano | Pro Tools TDM Systems (Mac) | 8 | 10-11-2004 10:48 AM |
