#31
Re: Audio tracks stop playing back/outputs disable
Autotune 5 HEAT Slate FG-X, VCC, Trigger Stylus RMX I have already removed all my Massey plugins and Sonnox plugins for other reasons. I'm familiar with out of date plugins causing problems, although Avid says all the plugins I have are supposed to work (because they worked with 9 HD with NO problems). But I'm a little bit worried that this is a little more serious problem. I'm like you, I don't have time to scale back to only the Digi Rack plugins right now.
Pro Tools 10/11 HD, Mac OS 10.8.2, Mac Pro 2 x 2.4 GHz 6-Core Intel Xeon (June 2012) 64 Gig RAM, Avid HDX Card, OMNI HD I/O, 192 HD 16x16, Artist MC Control, Firewire audio drives, Sony Bravia 42" HDMI monitor, Acer 24" monitor |
#32
I see by searching that DigiTechSupt has made multiple posts both today and yesterday, so I'm hoping one more bump here might help him see this thread.
#33
on a similar note, sometimes the master fader will ignore it's own automation (like a fade at the end of a song) and although the plugins work on the master, the fade doesn't.
same deal, closing and re-opening the session fixes this bug. anyone else? seems likes it happens after an import (similar to the main issue of this thread) |
#34
bump
#35
I spoke with Support this morning in the Uk and they are now aware of the issue.
#36
Reckon they will share with their US counterparts? Being aware of the issue....Do they acknowledge it indeed happens, or are they trying to reproduce? Thanks again.
#37
Hi, they are trying to reproduce. It was the first time that they had heard of this issue. Im sorting out a session to send to them so the can analyse.
#38
Thanks, let me know if I need to send anything.
#39
Same problem here. Closing re-opening the session brings things back.
This is like the random busses stop working issue but this time it´s the entire track that stops playing. Problem is: They were never able to fix the bug in years. I really hope this one will be fixed. Could be a reason to go back to 9. This new bug happens way more often than the older one. I get this 4-5 times per day. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#40
Same problem here...
It happens only when instantiating new rtas plugins... or creating new tracks or new auxes... Generally never happens when instatiating new tdm plugins... A faster method for restoring everything is going into playback engine menu and re-selecting HD TDM... it will close the session and re-open it and everything will work again...
some of my vocal audio tracks not playing back...help | superdood | Digidesign Hardware & Software | 13 | 11-19-2021 08:31 AM |
Audio tracks stop playing back/outputs disabled in PT 9.0.6 | mingojr | macOS | 0 | 08-12-2013 05:25 PM |
Recorded audio is not playing back in sync with other tracks | ATLracing | Getting Started | 4 | 07-08-2013 05:52 PM |
Those getting "audio tracks stop playback/outputs disable" Questions? | crizdee | macOS | 15 | 09-25-2012 08:10 AM |
Tracks Stop Playing Back 7.2.1cs1 | tomhartman | Pro Tools TDM Systems (Mac) | 0 | 11-21-2006 01:36 PM |
