Eucontrol 3.6.0 Firmware 1.5.4 (Artist Mix) Not Working
Hello All!
This is a new installation, no previous Eucontrol software/firmware installed. I installed Eucontrol 3.6.0, and updated the firmware to 1.5.4 on the Artist Mix controller. There seems to be a communication issue, as the OLEDs display what appears to be an empty "knob position box". On the Workstations tab in the "My Workstations" column my computer does show up, but in the attached column there is an "X", not a check as described in the User guide. I have also made sure that Eucon is enabled in Pro Tools System>Peripherals>Ethernet In the "Assignments" tab, all 8 channels are "auto assigned", but I cannot lock either the entire surface or transport, as the boxes will not activate. The controller is plugged directly into the ethernet port on my computer, no switch/router. I have uninstalled the Eucontrol software and reinstalled it, and no change in the symptoms. I have tried three different patch cords, a full cross over cable Pins 1,2 and 3,6 as well as pins 4,5 and 7,8. A partial crossover cable (10-100bT) only pins 1,2 and 3,6, as well as a standard 568B patch cable, just in case the ethernet card happened to be auto sensing. No change in the symptoms with the crossover cable. The standard 5658B cable did not work. Being the fact that this controller is used, I did a self test and it appears to pass with flying colors. I have also checked the network settings on the controller and DHCP is enabled. I am using Pro Tools 10.0.0, with an Mbox Pro interface. Included below is the Sandra report in case any of that information is needed. Any help would be greatly appreciated! Thanks in advance for your time. Oady Sandra Report 21 MAY 17 SiSoftware Sandra ID Host Name : CS250-PC Workgroup : WORKGROUP Computer Model : Sweetwater Sound CS250 Serial Number : 025013******* Chassis : Desktop Mainboard : Intel DH67GD Serial Number : BTGD13****** BIOS : Intel BLH6710H.86A.0146.2011.1227.1631 12/27/2011 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz (4C 3.09GHz, 3.1GHz IMC, 4x 256kB L2, 6MB L3) Socket/Slot : FC LGA1155 Chipset Memory Controller : Intel Core (Sandy Bridge) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.33GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Patriot Memory PSD34G133381 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Patriot Memory PSD34G133381 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Patriot Memory PSD34G133381 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Patriot Memory PSD34G133381 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : LG E2360 (1920x1080, 23.1") Video Adapter : Intel(R) HD Graphics Family (6CU 30SP SM4.1 850MHz/1.1GHz, 80kB L2, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Graphics Processor Compute Shader Processor : Intel(R) HD Graphics Family (30SP 6C 850MHz/1.1GHz, 80kB L2, 64MB DDR3 1.33GHz 128-bit, Integrated Graphics) Storage Devices Seagate ST31000524AS (1TB, SATA600, 7200rpm) : 932GB (D:) Seagate ST500DM002-1BD142 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) : 466GB (C:) Cruzer (15.5GB, USB2/NVMe) : 14GB (E:) Seagate ST3000DM001-1ER166 (3TB, USB3/SATA300/600, 3.5", 7200rpm) : 3TB (F:) (G:) Logical Storage Devices Audio (D:) : 932GB (NTFS, 4kB) @ Seagate ST31000524AS (1TB, SATA600, 7200rpm) System Reserved : 100MB (NTFS, 4kB) @ Seagate ST500DM002-1BD142 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) Glide (E:) : 14GB (FAT32, 16kB) @ Cruzer (15.5GB, USB2/NVMe) Sys Backup (F:) : 491GB (NTFS, 4kB) @ Seagate ST3000DM001-1ER166 (3TB, USB3/SATA300/600, 3.5", 7200rpm) Nat Inst (G:) : 488GB (NTFS, 4kB) @ Seagate ST3000DM001-1ER166 (3TB, USB3/SATA300/600, 3.5", 7200rpm) Hard Disk (C:) : 445GB (NTFS, 4kB) @ Seagate ST500DM002-1BD142 (500.1GB, SATA600, 3.5", 7200rpm, 16MB Cache) Peripherals LPC Hub Controller 1 : Intel H67 LPC Controller Audio Device : Intel Cougar Point High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Disk Controller : Intel Cougar Point 6 port SATA AHCI Controller USB Controller 1 : Intel Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Intel Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : Intel Renesas Electronics USB 3.0 Host Controller FireWire/1394 Controller 1 : Intel VT6315 Series Firewire Controller SMBus/i2c Controller 1 : SMBus Dev Drv 1 Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet, 100Mbps) Wireless Adapter : NETGEAR WNA3100 N300 Wireless USB Adapter (802.11n (HT), AES-CCMP, 137Mbps) Operating System Windows System : Microsoft Windows 7 Personal 6.01.7601 (Service Pack 1) Platform Compliance : x64 Performance Enhancing Tips Warning 2513 : TPM not detected. Some security features are unavailable. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: Eucontrol 3.6.0 Firmware 1.5.4 (Artist Mix) Not Working
Update: I downloaded the Bonjour browser program, and I do have EuConProxy_tcp listed in services, as well as the link local IP address.
Just to check did the Mix add OK on the surfaces page ?
Yes Sir it did appear in "My Surfaces". I also removed it, and added back. No change in the symptoms.
Thanks for your reply! |
The X does mean you are connected. Could you screen grab both the Workstations and Surfaces tabs ?
Mr. Jones,
Here you go! Another tidbit of info that I forgot to add in my initial description. When I power up the controller, and the computer is off all of the OLEDs have the Avid logo. As soon as I power up the computer, the logo goes away, and I am left with what I think is the "knob position box". Thanks again for your help, it is much appreciated! Todd |
It seems to be partially talking, and you said you had the Eucon pref enabled in PT right ? You could try temporarily disabling the firewall to see if that helps.
Eddie, does PT 10.0.0 really work with Eucon 3.6 ?? I seem to recall we had to use the 2.7.1 for example when we had PT10HD ...
I was wrong sorry, you do need v2.7.1 to run PT 10.
Hey folks,
I was doing the firewall suggestion, before I realized Southside had posted about 3.6 not working with PT 10.0.0. As I was adjusting my strategy, my place was hit with a wicked storm system, that unbeknownst to me was moving through my area at approximately 55 mph! Wind gusts over 60 mph, hail, lightning, etc. It was pretty nasty, took out power, killed my internet, and bit my computer! Today I finally got my computer up and running, downloaded 2.7.1, and all is great in my world! Thanks Eddie Jones and Southside Music for your help with this issue. It is much appreciated! Todd |
EuControl 3.6 crashing when Artist Mix connects | [email protected] | Artist Series | 10 | 06-02-2017 01:32 PM |
Artist Mix not appearing in EuControl | JakeHa | Artist Series | 0 | 07-22-2016 04:39 PM |
Artist series/EuControl power up sequence? | PeterScherr | Pro Tools 12 | 2 | 04-19-2015 06:05 AM |
EuControl v3.2.2 for Artist and S3 Now Available | Avid | Technical Alerts | 0 | 04-03-2015 07:23 PM |
Artist series, Eucontrol, Support: Sorry, I don't get it. | OTARI | Artist Series | 15 | 08-09-2013 08:07 AM |
