Confused by 888/24
I picked up an old mix system off ebay last month but something has me puzzled.
I have output 1-2 of the first 888/24 set as my main stereo outputs in pro tools. I have an 8 way Stereo jack to jack loom so I changed two of the jack's to xlr to fit the output of the 888/24. This then goes to my main mixer. I noticed a hum in the monitor mix coming from these two channels. So thinking I may have wired something incorrectly (ground loops ets) I got two xlr to jack cables (mic cables) and replaced my loom. Now I get really bad phasing but the hum is gone! Any ideas? I also noticed that only channels 1 & 2 meter lights are working on the first 888/24. I can understand this when playing back as I am only using 1-2 outs but when I am recording and have several channels in use, surely the 888/24's should be responding to input? Is there a setting I need to change? |
Re: Confused by 888/24
Are you going from balanced (888) to unbalanced (mixer) or is it balanced all the way? I'm suspecting you're connecting wrong pins because of the unbalanced jack.
XLR: 1 = ground, 2 = positive, 3 = negative TRS: sleeve: ground, ring = negative, tip = positive So... Your phasing issue will go away once you connect positive to positive and negative to negative. And the ground hum will go away if you unbalance properly. Live folks do it by connecting negative to the ground pin, but at least HD interfaces say you would have to leave negative unconnected (thus only connecting ground and positive) Double-check your connections and it should be okay.
The 888/24 meters always show the Output Level, you can't change that. You are supposed to view the recording level of the Audio Channel you are recording on the software meters in the Mix Window and/or Edit Window
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
Confused about I/O??? | bvcreative | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 05-03-2008 08:41 AM |
:confused: Confused Re: Expansion Chasis | BA Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-26-2008 08:24 AM |
really really confused... | jamaicadave | General Discussion | 3 | 03-15-2005 02:13 PM |
So confused | Pete Evick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-20-2003 05:01 PM |
ok, I'm still confused about 6.1...... | Mikhail | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 07-22-2003 01:04 AM |
