Old 01-11-2013, 01:28 PM
roberts roberts is offline
Default Hardware Delay Compensation broken
Hardware insert ADC does not work on a Digital 192 with HDX.
Old 01-11-2013, 01:30 PM
Craig F Craig F is offline
Default Re: Hardware Delay Compensation broken
a little detail might be a good thing
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 01-11-2013, 05:30 PM
- duplicate a track
- add a hardware insert to copied track
- reverse phase on one track
- no null
When you enter in the delay of the i/o then add the hardware insert there is no null.
Old 01-13-2013, 09:46 PM
ilovemyssl ilovemyssl is offline
There's a few things to consider:
- have you correctly determined the actual delay the hardware unit causes?
- if the hardware unit is changing the sound in any way (EQ / compression etc) then it won't null because it's changing the sound
- double check that you have Delay Compensation active (I've randomly discovered it turned off when opening a session)
It would probably help if you listed exactly what you're trying to do (ie. what hardware unit you are using as the insert, whether you are routing to other plugins or busses, what settings you have for your Delay Compensation engine etc)
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix
2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1
SSL 4056G
Old 01-14-2013, 04:20 AM
crizdee's Avatar
crizdee crizdee is offline
I'm guessing he means regardless of any specific piece of outboard or in bypass or straight through its not staying in phase using the 192 digital as apposed to using an analogue 192?
Partly guessing, but Roberts been around long enough to assume the basics.
I know digital has a different latency time from analogue 192's but i thought as long as both inputs and outputs were matching 1-2 in and 1-2 out on the same interface etc it should work.
Ive never owned a 192 digital so can't really comment further or check. but anyone with a 192 digital could do a simple ping test? out and back in again and see if its aligned.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-14-2013, 05:32 AM
psmworld's Avatar
psmworld psmworld is offline
another interesting and really annoying thing is:
recording an audio-track that is sent to an aux. even without plugins it´s out of sync to the other tracks and phasy between the audio-track and the aux that it is sent to.
Selling:
Old 01-14-2013, 07:14 AM
crizdee's Avatar
Thats because only the audio track you record onto is bypassed from the delay compensation when recording. so the aux will add a small amount of latency. barely noticeable on non rhythmic parts but rhythmic parts will phase.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-14-2013, 07:18 AM
psmworld's Avatar
then why is it, that if i also route the audio-track to the master and mute the aux it is also sent to, the audio-track is also way behind?
this worked on HD Accel and it was nice to already work on eq/comp/reverb-settings on the aux, without changing anything to the singers headphone-mix that´s sent from the audio-tracks
Selling:
Old 01-14-2013, 12:55 PM
Originally Posted by roberts View Post
- duplicate a track
- no null
I was thinking more alongs the lines of OX and PT versions
and what hardware you're using
you know the Help Us Help You stuff
Thank you,
Craig
Old 01-16-2013, 09:42 PM
2010 12 core Mac Pro. 10.7.3 HDX
First 3 interfaces - 3 x 16x16
4th interface Digital 192
Sample Rate 96K
Pro Tools 10.3.0
I recorded through a digital compressor I had the comp connected digital though the 192 AES card and had the preset bypassed so there was no effect dry signal but using the AES signal to measure the delay.
I then duplicated the track and added the bypassed compressor as an insert.
I used a trim plug-in to reverse phase on one track.
I even slipped the track one sample at time to find a null but it never null.
The best cancellation I could ever get was -38dBI only have analog Avid convertors no digital ones to try only only blue 192's
Delay Compensation in 10.3.8 seems to be broken spiritfallrecording Pro Tools 10 6 01-19-2014 07:24 PM
Delay compensation of I/O plug on parallel Auxes broken? bleen Pro Tools HDX & HD Native Systems (Mac) 12 11-20-2013 06:15 PM
Delay Compensation broken ArKay99 Pro Tools 10 8 06-22-2012 01:12 PM
Delay compensation broken jturner Pro Tools TDM Systems (Mac) 33 09-16-2009 03:55 PM
Hardware Delay Compensation loosestones Pro Tools TDM Systems (Mac) 0 04-07-2009 11:51 PM
