MMC to Motu MIDI Express
I am attempting to use Pro Tools as the transport for Neve VR Automation, using a Motu MIDI Express XT.
The setup is as follows. The Motu is the master clock and is sending timecode to the Neve and to Protools. This is works fine. But i want pro tools to be my transport, and not the Motu Express Software. I thought i could use MMC in Protools to simultaneously control the Motu while also receiving timecode back so everything is synced. This too seems to work fine. My problem is that while Protools is in MMC mode, it does not want to spit out any Audio....... What am i doing wrong? Or can anyone suggest a better solution to this ??? thank you |
Re: MMC to Motu MIDI Express
Sounds like you probably have a good number of outputs. Easiest method would be to record Ltc into protools from the motu and then play that back out a spare output into flying faders Ltc input.
This way, time code will be generated each time protools transport is in play |
Anything better than the MOTU Midi Express 128? | Imagine | Pro Tools TDM Systems (Mac) | 8 | 10-13-2010 01:51 PM |
PT8 and MOTU Midi Express 128 | jkeefauver | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-11-2009 05:24 AM |
MOTU Midi Express XT USB | dans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-24-2003 06:41 PM |
MOTU MIDI Express | Princeton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-10-2002 12:46 AM |
001 with motu XT midi express | quaz | MIDI | 0 | 04-28-2001 07:41 AM |
