Old 10-10-2015, 07:21 AM
KGraham045 KGraham045 is offline
Default ProTools Deck Emulation
I have a Sony DMX R100 and am trying to get Transport control over ProTools HD10.
I am using a KeySpan USB serial adapter and am trying to get Jog Wheel and Transport and Jog Wheel control over Remote 9 pin. Anyone have any advise? Or experience getting this to work?
I'm not wanting a control surface just looking to make ProTools a virtual Tape machine.
Old 10-10-2015, 09:40 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: ProTools Deck Emulation
Only way I have found transport control to work, is to use the black cable that came with Machine control stand alone back in the day!!
IMDB
Old 10-10-2015, 09:54 AM
I purchased the Machine Controll license and cables separate. The cables appear to work. Are the Deck Emulation cables different from the Deck Control cables?
I believe I might have Serial Control Cables. But when I select Serial Control in Perhipals my system looses sync. Anyways When selecting Deck Emulation what device should I select for the Sony DMX R100? It's default is BVW75....
BTW I am running OS 10.8.5 on a Mac. I know that Yosemite and the Serial Adapter don't work.
Do you have transport and jog wheel controll over ProTools using deck emulation with the Sony DMX R100? I'm wandering if I'm doing something wrong or if this just won't work.
Old 10-10-2015, 12:58 PM
Postman Postman is offline
Pro Tools uses different cable wiring depending on whether it is a controller (master that commands another deck) or deck emulator (slave, which I believe is the configuration you need). The difference I think is to swap the T and R wires. I used to keep a short crossover adapter around that would swap those pairs when necessary.
Old 10-10-2015, 01:14 PM
By chance do you remember where you got the adapter? Sounds like that might be the easiest way to get this workin
Old 10-10-2015, 02:23 PM
I built one with a male 9D on one end and femaile on the other. google "RS422 crossover" and you'll be able to find pinouts if you're into DIY and adapters for purchase. Hope it does the trick for you.
The adapter swaps pins 2-3, 4-6, 7-8. You can wire 1 to 1 and 9 to 9 if you are anal but most people just leave them unconnected/ They might make a difference in very long runs.
HTML code is On
ProTools and VTR Deck Control for Live Event / TV Broadcast NathSteeley Post - Surround - Video 2 12-14-2014 04:00 PM
PT10 Deck Emulation Mode Eric Seaberg Post - Surround - Video 2 04-05-2012 09:09 AM
VCA emulation Jermak Windows 14 02-14-2011 05:04 AM
Machine Control Deck Emulation problem darkwar3 Pro Tools TDM Systems (Win) 1 12-23-2008 12:51 PM
Recording from stereo cassette deck into ProTools casperso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-26-2004 05:11 AM
