Old 07-24-2005, 10:19 PM
agock agock is offline
Default PT MIX 6.4.1cs4 who\'s using?
Everyone happy with 6.4.1cs4 for MIX.
I haven't been able to get any of the 6.4.1 versions to work properly. I'm still on 6.2.3. I know others out there have been able to get 6.4.1 versions to work for them, albeit with some tampering when opening each session.
next!
G4 933
1G ram
OSX 10.3.4
PT 6.2.3
1622 1/0
888 1/0
Old 07-25-2005, 04:17 AM
StadiumRocker StadiumRocker is offline
Default Re: PT MIX 6.4.1cs4 who\'s using?
What doesn't work in 6.4.1 that works in 6.2.3 for you? Just curious. I've used both versions and 6.4.1cs3 certainly still has issues, but far fewer than 6.2.3 did (for me).
And no, I haven't installed cs4 yet on my one remaining Mix rig because I'm wary of this fix they implemented - just taking away +6dB fader gain scares the hell out of me, with no way to know if a session truly opened properly. This kind of fix says a lot about how Mix users have been shafted in general.
I wish Digi would implement the one fix that really matters - fix HTDM in 6.4.1.
Old 07-25-2005, 07:01 AM
CHRIS AIKEN CHRIS AIKEN is offline
Amen to that!!
Chris
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate
Old 07-25-2005, 05:00 PM
Stadium Rocker
The problems with 6.4.1 I've had;
- Volume levels changing for no apparent reason. Especially with bussing to AUX. There was a way around it that others found, I can't remember, I think it had something to do with reseting something each time you opened a session.
Either way, I couldn't rely on a session being reopend exactly as I had left it. Others have found the same problem. If you haven't had any problems, that's great, for some reason it wasn't happening for me.
Thanks
Anyone using 6.4.1cs4?? Anyone.
G4 933
1G ram
OSX 10.3.4
PT 6.2.3
1622 1/0
888 1/0
Old 07-25-2005, 05:06 PM
tball tball is offline
Ive had the db drop in 6.4.1cs3 as well. I should have never updated. Everything was fine for me with the original 6.4.1. To remedy the situation you have to open hardware setup and deselect your second interface and select it again. It is quite annoying. Im going to try the cs4 update tommorrow and see if it sets me straight.
Mix + G4 dual 1.2 1.5 gbRAM OS10.3.8 PT 6.4.1cs3 JH-16!
Old 07-25-2005, 05:14 PM
I put it on one of our systems. No complaints yet, and if there was a problem, this engineer would definitely complain.
Old 07-25-2005, 06:55 PM
M2E M2E is offline
Do you guys think that we will get the shaft in Tiger as well. Or will that ne a cs update? Please Digi-look out for us.
Thanx
M2E
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies)
YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc
Old 07-25-2005, 07:02 PM
No shaft here. Digidesign made it explicitly clear that MIX development ends with v6.4.1. Quite frankly, I'm shocked we got a cs4.
Old 07-26-2005, 05:52 AM
Don't be shocked it's pretty much their obliagation to provide it...we paid for stable software.They can stop supporting and updating a software as they wish...but they better make damn sure that the last version is without any major bugs.That's not the case so in my opinion they've still got work to do.
Chris
Old 07-26-2005, 09:06 AM
Kris Kris is offline
I really appreciate this bug fix. For me it was a big one... It was the most annoying issue I've had with PTools since installing PT III in 96. I will be running it after my latest project goes to the mastering house, but NOT BEFORE!.
My studio: http://www.logcabinmusic.com
PT 7.3.1cs4 FMP bug Steve MacMillan Pro Tools TDM Systems (Mac) 1 09-05-2007 10:09 AM
OS X.4.10 & PT LE 7.3.1cs4 Craig Woolard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-10-2007 03:04 PM
Mac OS 10.4.10 and Pt 7.3.1cs4? logandrum Pro Tools TDM Systems (Mac) 2 07-30-2007 10:13 AM
Mac OS 10.4.10 and Pt 7.3.1cs4? logandrum Pro Tools TDM Systems (Mac) 0 07-30-2007 12:21 AM
QT7 + PT6.4.1cs4 + OS 10.3.9 = OK? JR Fountain Post - Surround - Video 4 03-09-2006 08:01 PM
