How good is the monitoring path in the command8 ?
Should I bother going thru it,i'm already using a Coleman TB4 ,The command 8 is closer to me when I mix,easier to reach but before i repatch I could use some opinions.
Thanks francois
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1 - D-command 24- Trinnov Dmon6 |
Re: How good is the monitoring path in the command8 ?
Hello,
I personally found it to be slightly noisy! compared to not using it and monitoring directly to my amp!! Regards Chris
It's not rocket surgery |
Ok I'll stick to my Coleman:)
Thanks Francois
What is a good output path? | mij sang | Tips & Tricks | 12 | 01-20-2009 06:02 AM |
Update! Distortion in Monitoring path! PT 7.3.1 | Sonic Nomad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-18-2007 12:23 PM |
Mbox2 Pro: Zero Latency Monitoring Path? | jeff markham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-25-2006 09:15 AM |
Is there a good "monitoring box" for around $800? | bpert | Pro Tools TDM Systems (Mac) | 19 | 06-01-2006 10:38 PM |
Will a good quality patchbay hurt my signal path? | jic3 | Pro Tools TDM Systems (Mac) | 13 | 11-19-2001 03:42 PM |
