Old 08-21-2019, 04:31 PM
emmany emmany is offline
Default Eleven Rack Firmware update problem !!!
Hi Guys ,
I recently purchased a Eleven rack with the firmware version 1.02 ,connected to a Mac running OS Mojave . I tried updating it to the version 1.0.3 .But every time I try updating with it gives the following error
"The firmware update failed.
Please turn your Eleven Rack off and on again and then retry this updater to make sure that valid firmware is installed."
Any kind of help would be greatly appreciated .
Cheers,
Emmany
Old 08-23-2019, 11:22 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack Firmware update problem !!!
Did you try this
http://avid.force.com/pkb/articles/e...ssage/en422359
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 08-23-2019, 03:29 PM
Hi , Thanks mate for your reply . The link you sent was for the expansion pack 2.0 , but I have only the update to 1.0.3 . I still tried the method the link suggested , still getting the same error. I m running MacOS Mojave .Cheers , Emmany .
Old 08-24-2019, 04:21 PM
Benoni's Avatar
Have you tried using a different driver for the 11R and then do the update.
That is what use to work on Windows.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Firmware Update Eleven Rack 2-but no new things Yehudi Eleven Rack 6 07-31-2014 01:57 AM
Eleven Rack Firmware Update v 1.0.3...now! TheChimp Eleven Rack 77 03-14-2012 11:20 PM
Eleven Rack Firmware Update Version 1.0.3 Avid Eleven Rack 0 08-06-2010 12:26 PM
Eleven Rack Firmware Update Version 1.0.3 Avid Technical Alerts 0 08-06-2010 11:50 AM
Eleven Rack Firmware Update Version 1.0.2 Avid Technical Alerts 0 03-03-2010 10:45 PM
