Old 03-27-2002, 10:29 AM
Traveler Traveler is offline
Default Recommendation Please?
Greetings,
I have a Korg TritonPro connected to inputs 3-4 of the DIGI001. Is it recommended that I use a balanced or unbalanced cable?
Regards,
Earl [img]images/icons/confused.gif[/img]
2.66 GHz Quad-Core MacPro, 3gb RAM, OS X v10.5.3, DIGI 003 Factory, Pro Tools LE 7.4.2
Old 03-27-2002, 10:35 AM
alk509 alk509 is offline
Default Re: Recommendation Please?
I'd go with balanced... although if you're not running more than just two or three feet of cable, unbalanced might work just fine.
Al K.
Old 03-27-2002, 10:43 AM
Thank you for the reply Al K. [img]images/icons/smile.gif[/img]
Old 03-27-2002, 11:06 AM
saintkev77 saintkev77 is offline
I think the triton pro is unbalanced...so it dosen't matter.
Old 03-28-2002, 02:42 PM
Per saintkev's reply...does that mean I should use unbalanced cables, or can I still benefit from using a balanced cable?
Earl
Old 03-28-2002, 02:58 PM
sfumato sfumato is offline
If the tritonpro has unbalanced outputs then it will not make any difference whether you use balanced or unbalanced cables.
Cheers,
Bryan
Recommendation for a USB Hub Dopamine macOS 2 02-13-2014 06:56 AM
DI Box Recommendation? timstar78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 02-26-2008 10:24 AM
Mic Recommendation asiabackpacker General Discussion 12 10-01-2005 01:18 AM
Recommendation dreamers General Discussion 3 12-26-2003 08:05 PM
DVD-RAM recommendation? snoopy Storage Subsystems 5 06-30-2000 12:54 AM
