Old 04-26-2014, 05:16 PM
markblasco markblasco is offline
Default Problems with PT8LE, Artist Mix
I recently purchased a used Artist Mix controller, and in the manual it says that it will run in PT8 in HUI mode. I have gotten the controller to be listed in the eucon software, and I see options for the controller in the peripherals menu (it gives me 8 different options for both input and output), but nothing I do causes the device to connect at all, I just have empty rectangles in each screen. If I go to the ethernet controllers option, it doesn't show any options at all.
So, does anyone know what I need to do to get this to work with PT8LE on a windows machine? It seems to be connected to the computer just fine, I just can't get it to work with PT.
Old 05-02-2014, 09:36 PM
Default Re: Problems with PT8LE, Artist Mix
Can anyone help me out here? I'm sure there's someone out there using PT8LE with the Artist Mix controller...
Avid Artist Control + Logic problems. matthihat Artist Series 4 02-03-2019 01:37 AM
Artist Mix newbie with problems - MC Video Eduardo Serrano Artist Series 2 05-14-2013 03:46 PM
Artist Mix Warranty Problems Bluto Artist Series 10 09-27-2012 12:58 AM
Track select problems with Artist Control Swurveman Artist Series 1 05-18-2012 10:41 AM
PT8LE graphic problems? postmike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-08-2009 01:08 PM
