Old 10-18-2011, 02:01 PM
amoretam amoretam is offline
Default Reaper rewire latency into protools
Today I realized that reaper is adding a significant amount of latency to my protools project. I use reaper just to host my VI's but I do all sequencing in protools.
An example of what is goin on:
-write some kicks aligned with the grid in protools
-when I hit play the kick is a little behind compared to the CLICK in PT.
To make sure I opened the same VI in Protools and assigned it to the same midi track and there is absolutely no latency while playing back.
I would appreciate any help here, maybe I am missing something
Thanks alot
Old 10-19-2011, 09:41 AM
Default Re: Reaper rewire latency into protools
Help!!!!
Old 10-19-2011, 12:57 PM
TOM@METRO's Avatar
TOM@METRO TOM@METRO is online now
Check your buffer settings... Keep 'em low.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-19-2011, 01:12 PM
Tom Metro, if you read carefully this is not about buffer settings, what I am experiencing is an Extra Latency added by Reaper, ... please read carefully
Click track in PT is not aligned with VI's output coming to PT from Reaper.
Thanks
Old 10-19-2011, 08:38 PM
hello people please check out this thread, I am alone here with this problem..
Is that normal that Reaper VI's are behind the Click in PROTOOLS???
Old 10-21-2011, 04:18 PM
i cant beleive i am alone here, why is Reaper not in synch with protools perfectly??
Old 10-27-2011, 12:18 PM
YYR123's Avatar
YYR123 YYR123 is online now
IDK b/c i don't rewire....YET. But shouldn't you expect some latency?
Did it ever work w/o the latency that you have?
Can't you just manually adjust the latency..???? On the Vi'd tracks....
Daniel
Old 10-27-2011, 02:52 PM
spenner spenner is offline
Thanks alot
Hi.
I responded to your thread over at the Reaper forum.
Old 10-27-2011, 03:35 PM
This could be a result of the buffer in Reaper, as Tom stated. Did you change the buffer settings in Reaper? The VI audio goes from Reaper into PT. A too high buffer could cause latency from Reaper.
Old 10-27-2011, 06:03 PM
that is not suppose to be an adequate rewire behavior, Buffer size changes in Master program should change accordingly inthe Slave program.
It is like that when I do it with Cubase/Reaper, no matter the buffer size, they are always in sync, that's what rewire is all about..
Thanks people, let's see if we find out what this strange behavior is all about.
cheers
Reaper Rewire Latency Issue dougdude9 Pro Tools 10 4 09-17-2013 02:08 PM
ProTools and Reaper rewire johndaw Pro Tools 9 8 07-24-2013 10:51 AM
Rewire Reaper with ProTools for audio processing Zarabozo Windows 4 01-21-2013 09:59 PM
Protools + Reaper (Rewire) synchrony problem Zarabozo Windows 4 11-28-2012 09:53 PM
ProTools Rewire & Reaper jayprotools Pro Tools TDM Systems (Mac) 29 11-30-2010 08:48 PM
