Old 06-09-2005, 06:40 PM
oneamazinkid oneamazinkid is offline
Default reverting to internal clock...
so, i am having problems with my system. i am running a g4 1.42 dual processor, digi002 rack, focusrite octopre. the octopre clock source is adat. i have never had a problem with anything, but as of late, i get a protools warning stating, "the external clock choice is invalid. reverting to internal." has anyone had this problem?? what should i do??
Old 06-09-2005, 06:50 PM
Default Re: reverting to internal clock...
If the Octopre is set to ADAT clock source, the Digi must be set to internal. If the Octopre is set to internal, the Digi must be set to ADAT.
Quad 2.5 G5, 4.5G RAM
Old 06-09-2005, 07:02 PM
it has always worked. it is set up the same as before. nothing has changed.
Old 06-09-2005, 07:03 PM
also, i am running pt 6.9
anyone??
Old 06-10-2005, 10:51 AM
DigiTechSupt's Avatar
Have you checked the optical cable to make sure it's firmly connected and/or tried replacing it?
Are you sure the Focusrite is set to internal clock?
Avid Audio Tech Support
Support FAQ
Old 06-10-2005, 11:21 AM
Something has changed, you just don't know what - but what I wrote is still true.
Old 06-10-2005, 12:20 PM
Mr. Grotto Mr. Grotto is offline
Check to see that you're using an ADAT-compatible sampling rate (44.1 or 48).
here's to ben.
Old 06-12-2005, 06:50 PM
Does the octopre power up before or at the same time as the 002? Maybe your AC outlet has a loose connection? Did you add any high current draw AC power hog (like a new air conditioner) that makes the power sag when it starts? Just a thought as anything that upsets the clock in the octopre would cause the 002 to revert to internal.
PT 8.0.5 keeps reverting to internal clock Fastermouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-12-2011 11:27 PM
Invalid clock source reverting to internal!! route44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-18-2006 12:13 AM
Reverting to Internal Clock bennybob1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-20-2005 05:21 PM
HELP-External Clock Invalid, Reverting To Internal Clockwork12782 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-15-2004 12:43 PM
external clock is invalid. reverting to internal.. lowlight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-12-2004 12:58 PM
