Old 07-03-2015, 10:01 AM
Siegfried Meier Siegfried Meier is offline
Default Dashed lines in MIDI tracks when I cut/copy or paste notes
What's happening in 12 that's changed? There's strange dashed lines showing up in MIDI tracks when I cut/copy or paste MIDI notes. I'm also still having issues with Massey's DRT that won't allow me to tab to MIDI notes all the time - very inconsistent behaviour. It never happened in 11 and previous versions. Also, undo doesn't seem to undo a paste, and pasting a note too close to another one deletes the first note…all weird stuff that never existed before.
Does anyone have insight on what's going on?
Thanks,
Sig
Old 07-03-2015, 12:31 PM
Shan's Avatar
Shan Shan is offline
Default Re: Dashed lines in MIDI tracks when I cut/copy or paste notes
There's been a few MIDI bug fixes. The only new MIDI feature I'm aware of is the new "Manual Tempo Entry with Conductor Enabled".
Can you post a screen shot of that. Thanks.
...and yes, MIDI needs more attention. I'm hoping we'll see new stuff fairly soon down the road.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 07-03-2015, 12:58 PM
http://www.siegfriedmeier.com/screen...MIDI%20Bug.png
Old 07-03-2015, 01:06 PM
Shan's Avatar
Seeing that also. I'd consider that a UI bug/issue, as it's very sporadic and random.
Shane
Old 07-03-2015, 09:44 PM
Ianduarte Ianduarte is offline
I guess what you see are the blocks. Select to view clips or blocks and consolidate them. This will make these lines go away.
Old 07-03-2015, 10:59 PM
Shan's Avatar
These are dotted lines that weren't in previous versions. Prior versions had the normal solid lines it always had that represented the clip boundaries in notes view. The dotted lines are very random and don't always show. Sometimes they're dotted, and sometimes they're solid. They'll also randomly change. That random behavior I would deem a UI bug/issue new to 12.1.
Shane
Old 07-04-2015, 07:33 AM
Well, even if this IS only a graphical bug, all of those other things I'm experiencing are real, operational bugs…otherwise they'd still be there with the same session when I open up 11HD.
I was hoping the latest release would fix them, but it appears they are 100% the same as they were in the first release of 12…a shame, since it stops us from actually doing anything productive with the latest version.
Old 07-04-2015, 11:29 AM
cherryrecording cherryrecording is offline
I've seen this in 11.3.1HD also: http://lookpic.com/O/i2/1859/iTi7kkp.png
If I open the session in 10.3.8HD the lines appear normally.
It doesn't affect the audio in any way, so I just consider it another PT quirk.
Old 07-04-2015, 03:00 PM
Eric Lambert's Avatar
Shane
Unfortunately, that's not the case. We don't see it often but we do see this in PT 10.3.10, and prior versions, too. Graphically it looks exactly like the above screenshot. Technically, MIDI information might be fine.
Old 07-04-2015, 03:18 PM
Emcha_audio's Avatar
Emcha_audio Emcha_audio is offline
Thanks,
Sig
Can you try trashing your prefs, I have worked on 12.1 today and I was able to undo every paste I did. Also as from notes being pasting and deleting the previous notes, if you select a region and that region has silence before that note, that silence will also be pasted erasing what could previously be where the silence falls. This is not new.
Manny.
PT12HD AAE -6101 Error Carl Sealove Pro Tools 12 18 06-02-2016 04:16 AM
HDX lowest buffer setting in PT12HD or 12.1 propower Pro Tools HDX & HD Native Systems (Mac) 2 07-03-2015 11:06 PM
Upgrade from PT11HD to PT12HD...? TrentWilliams Pro Tools 12 28 05-27-2015 07:49 PM
No PT12HD subscription plan? Tim R. Pro Tools 12 24 05-04-2015 04:01 AM
My PT12HD wishful thinking antonis Post - Surround - Video 21 11-06-2014 06:58 AM
