Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
  #21
Old 04-24-2011, 11:39 PM
abt abt is offline
Default Re: PT Hangs at DAE Loaded message
Scrap that last post. I can open whilst holding the n key and get the playback engine.
How do I start in ASIO mode? Sorry to be such a newb, I've never had to do any of this before, I guess I've been lucky in the past that it just worked.
  #22
Old 04-24-2011, 11:42 PM
ASIO4All works unless you have an ASIO device connected.
Aaron Mulqueen - 001 HD Native
  #23
Old 04-25-2011, 03:02 AM
abt abt is offline
I've just done a new build with a different video card. No good.
I've tried ASIO4All, I can't launch the ASIO4All control panel.
  #24
Old 04-25-2011, 03:08 AM
abt abt is offline
Wait... Open in with ASIO4All by holding the n key at startup.
  #25
Old 04-25-2011, 03:18 AM
abt abt is offline
YES!!!!!!! Aaron!!! YES! After starting it with ASIO4All as the playback engine I changed the playback engine back to the HD Native card, restarted PT and it works!
Having said that I haven't tried anything yet but this is a major break through!
  #26
Old 04-25-2011, 07:16 AM
I love the "N" key trick
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
  #27
Old 04-25-2011, 07:32 AM
abt abt is offline
Thanks everyone for all your help. I really do appreciate it. Here's what I did:
- Installed ASIO4all
- Started Pro Tools holding down the n key
- When the Playback engine opened I selected ASIO4all as the "Current engine"
- Pro Tools then opens where you can change the playback engine back to the Native card.
I'm assuming that you could do this with any compatible driver not just ASIO4all?
Here's the killer, I did a restore of the system to the point before PT was installed using a ghost image. I did this because so many things were tried I wanted to make sure it was all cleaned up. I installed PT and it ran first time without any problem.
DAE Loaded hangs dmichael Windows 0 07-13-2011 11:54 AM
New Dell Laptop hangs on "DAE Loaded" PT8 Vista Neil Miller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-16-2009 04:30 PM
PTLE7.4CS4 w/ 002 rack hangs on DAE Loaded in Vista Scottbanger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-18-2008 11:04 AM
PT hangs on DAE Loaded g00db33r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 05-29-2008 01:52 AM
PT hangs on startup at DAE loaded justmull1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-20-2007 07:48 PM
