Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 12-28-2006, 03:30 PM
adam79's Avatar
adam79 adam79 is offline
Default M-Powered vs LE
Hi. I'm currently running pro tools le with the mbox 2 on a macbook pro (intel-mac). I'm interested in buying a control surface and due away with the mbox. I really like the M-Audio ProjectMix I/O, but if I get that I'll have to switch over to the m-powered version. I've heard that the M-Powered software is inferior to the LE, and that you get less plugins. Has anyone used both and have any suggestions? are the plug-ins that come with m-power the same as le's, except less, or does the quaility lack as well?
Thanks,
-Adam
adam79@toast.net
Old 12-28-2006, 04:08 PM
Bill Pillmore Bill Pillmore is offline
Default Re: M-Powered vs LE
I switched from PTLE to PT M-powered last year and I have not noticed any difference in the software or the plugins... only the interface is better! I am running 7x on an older G4 and 7.1.1 on my MacBook w/ FW1814 interface.
Bill
Bill
http://billpillmore.com
MacMini 2 Ghz, 2GB, OSX 10.6.4, PT 9
Old 01-01-2007, 12:21 PM
Barry Johns Barry Johns is offline
Go the Mpowered route. I am selling my 002r. I now have the Lightbridge and Protools Mpowered with Music Production Toolkit. Now I can use any coverter I want with Lighbridge. I use an RME Fireface 800. Now you can do this with the 002R, but only one external converter since there is only 1 adat in/out.
Good Luck.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 01-05-2007, 12:57 AM
cfb25 cfb25 is offline
So theres really no difference between the Le software and the M-powered? I had the idea it was dumbed down somehow.. Is this totally off base? I have an 002r, and if an 003 doesn't come out at winter namm I may be seriously looking at m-powered and a lightbridge or project mix... Thanks for the help.
Chris Beaver Music
www.myspace.com/chrisfrankmusic
The Note Music
www.myspace.com/thenotemusic
Dual 2.0Ghz PPC 3gb Ram, Digi 002R
Old 01-07-2007, 12:40 PM
SeanDerMan SeanDerMan is offline
There is no DV Toolkit support in MPowered, which means you'll never have timecode in MPowered.
I think... unless 7.3 supports DV Toolkit, but i doubt it.
i7 920, Asus P6T Deluxe V2, Win 7 64bit Ultimate, Asus NVidia 8400 GS x2, UAD-1, Digi 003R Factory with PTLE 8.03, RME Multiface, Cubase 5 32bit.
Old 01-07-2007, 12:52 PM
So for everyone that doesn't need timecode.... M-powered is just as good as le...
Chris Beaver Music
The Note Music
Old 01-07-2007, 04:20 PM
Unless Digi releases something great at NAMM, there is NO reason to really go the Digi LE route for the vast majority. Mpowered plus lightbridge, let's you use any converter you want. I sold my 002 Rack, bought a Lightbridge and M-powered for less than I sold my 002 Rack. I use my RME FF800 for converters, which I was doing with my 002 Rack as well.
Old 01-07-2007, 05:09 PM
edgarbc1 edgarbc1 is offline
i switched (albeit from an ancient AMIII) to M-Powered ProjMix
and am completely satisfied with the switch. The projmix is big so consider
your work area, but other than that its a good buy. It takes a little getting used
to using the board if you are used to your mouse, you need it close by and accessible
to get the most out of it.. but i like how it frees me from the mouse for certain tasks
If you intend to use other pre-s than what is onboard, i would consider seriously the
FW1814 or the Lightbridge...
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8
Old 01-07-2007, 06:49 PM
neiljohnstonii neiljohnstonii is offline
So the lightbridge is compatible with M-Powered? There is nothing on M-Audio's website that says it is one of the audio interfaces for M-Powered.
Old 01-07-2007, 08:35 PM
m-audio lightbridge web site
the website says it is compatible with 7.3...
digi compat page
M-Powered 8 Essential -> M-Powered 8 Upgrade Snowblind Pro Tools SE and Essential (Win) 2 08-09-2011 08:05 AM
mac osx, m powered fast track, pro tools m powered singdance6 Pro Tools M-Powered (Mac) 2 12-22-2010 10:24 AM
Please Advise are Pro Tools M-Powered Essential the same as LE M-Powered? jeremiah0812 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-19-2010 11:10 AM
PT M-Powered with FW400 bus powered audio drive? bruceup Pro Tools M-Powered (Mac) 5 07-06-2006 02:32 PM
bus powered interface + bus powered enclosure ? technician Pro Tools M-Powered (Mac) 0 03-20-2006 06:34 AM
