For experts - Spectrasonics Trilogy/ Atmosphere crashing PT
Hi all,
Was hoping someone might have had experience with weird crashes when either Atmosphere or Trilogy plug in is opened. The plugins have been working fine with OS X10.4.8 on a Dual G5 2.5 PPC machine running PT 7.2cs3 for a while now. All of a sudden opening up either of the plugins in even a new, clean sequence will crash protools (no error message generated). I did all the standard troubleshooting deleting all prefs, digidatabases, checked drive directory damage, etc. Even uninstalled and reinstalled Protools as well as Trilogy and Atmosphere. Even booted from an archived known good clone of the build - Still crashing. Previously a reinstall of Protools seemed to fix these issues for about a month, now that no longer seems to work. Spectrasonics is stumped so I'm hoping someone out there has been able to figure this out. Any info appreciated as rebuilding from scratch will be a nightmare. |
Re: For experts - Spectrasonics Trilogy/ Atmosphere crashing PT
I think the answer is simple. check the spectrasonics web site - I don't think those 2 plugins are compatible with new macs yet.
G5 PPC 2.5 is a 2 year old+ machine. Nothing new about this hardware.
I am using these plugs daily on a G5 2.7DP OS 10.4.9 You should not have issues. Check your buffer. Check your ram. Check your hard drive that your files stream from. In fact, you may want to move your sample data to another drive just to see if the drive could be on the edge of its life. Hope this helps.
--Jeremy |
Mark,
its a 2 year old dual processor 2.5ghz G5 tower. Not an Intel Mac. Spectrasonics is supposed to be releasing an Intel Mac version this fall. |
sorry - I thought you were running on a new mac
ran mem test on the ram - came up clean. Deleted DS_store files.
tried the .dat sample files from other drives - still crashing. zapped all caches, even tried newer version of PT 7.3cs3, clean install of PT 7.2CS3 This is driving me crazy and I'm good at troubleshooting. Any suggestions on buffer settings, I have tried multiple settings already, just hope I overlooked something simple. |
Do the instruments open up as stand alones? Are you running the latest versions of Trilogy/Atmosphere?
Adam Miele Pulse Music NYC (212) 358-7900 [email protected] |
Pref's/DigiSetup/databases to the trash? Have you? Should you? Yes! You could have a corrupt plugin in the cache.. it happens.
v
Chief Engineer Blackbird Studio/Sputnik Sound Nashville ,TN www.blackbirdstudio.com www.sputniksound.com www.vancepowell.com |
Hi raregroove
im using the same setup G52.5 dual with 10.4.9 and PT7.3.1cs3 i use trilogy atmosphere and stylusrmx,with no problems ive just reinstalled them all on a new drive and they all work fine(they all worked fine before as well) When you reinstalled them, did you first get rid of the older files ,like files in spectrasonics folder in application support, Where are your .dat files stored,where are the aliases? |
Atmosphere and Trilogy lost in PT8 | ChrisSimon | Pro Tools TDM Systems (Mac) | 6 | 01-06-2009 08:29 AM |
Atmosphere and Trilogy Wrappers in 7.4.2pr | quantise | Virtual Instruments | 4 | 07-24-2008 09:42 PM |
anybody digging the new Trilogy and Atmosphere | the dude | Pro Tools TDM Systems (Mac) | 28 | 07-06-2008 10:31 AM |
Spectrasonics Atmosphere / Trilogy | GORILLA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-26-2007 06:09 PM |
Trilogy or Atmosphere in PT 7.1 HD Not working? | sctstudios | Pro Tools TDM Systems (Mac) | 12 | 10-31-2006 02:11 AM |
