Old 08-13-2020, 04:50 PM
Armando Armando is offline
Default Core Audio not working with standalone app
Hello! I’m trying to run a stand-alone app with Core Audio but the inputs aren’t receiving signal. I’ve got two 192 I/O’s and using the first 1-8 inputs of the second 192 as some of the channels 1-8 on the first 192 I/O have been wonky. I set the first 8 channels on the first 192 as channels 9 thru 16 and on the second 192 the first 8 channels I’ve set as channel’s 1 thru 8.
Could this be the problem? I ask because Core Audio is just showing Inputs 1-2, 3-4, 5-6, and 7-8 in the apps global setup page. Output 1-2 is working fine(can see level meters in app) but input isn’t working although I can see the leds on channel’s 1-2 working on the second 192’s front.
Anyone know how to get this working? Thanks in advance!!
Old 08-14-2020, 12:33 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Core Audio not working with standalone app
Nope, it is working as designed. Only 8 i/o on HD systems coreaudio.
Janne
Old 08-14-2020, 01:43 AM
Ok but since I set 1-8 on the second 192 shouldn’t this be showing up via Core Audio Manager? Or is the first 192 the “default” 1-8 as far as Core Audio is concerned even though it’s set to 9-16 in the Digidesign hardware setup?
Thanks!!
Armando
Old 08-14-2020, 01:59 AM
JFreak's Avatar
Dont remember for sure but think it was first eight
Janne
Standalone Core Audio Manager? johnnmk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 02-09-2011 09:51 AM
Is there a standalone core audio driver for new imported_tupelohoosier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-13-2006 02:25 PM
6.9.2cs4 Or Standalone Core Audio phobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-07-2005 02:20 PM
Standalone core audio does not work... PCM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-10-2005 11:39 AM
standalone core audio driver - when ??? The Lone Roger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 07-26-2003 06:01 AM
