Old 05-09-2020, 06:57 AM
belasoul belasoul is offline
Default Premiere Pro AAF import Issue
The AAf comes from the Picture Editor who works in Premiere Pro 13.1.0
He exported a separate (referenced) AAF. The Audio Folder looks ok (12gB, in 38 min. program), the Audio Files get new (long number) names like Premiere normally does it.
The problem is that the (tiny) AAF File shows all 19 Audio-Tracks which only inculde 8 random Audio-Clips (which are not even re-linkable).
The Picture Editor re-imported the AAF to Premiere itself and it looks complete btw.
Any leads about what to try next?
MacOs 10.14.6, RME Fireface UC / UAD Apollo, PT Ultimate 2020.3
Mac Pro 6.1/12-core,64GB RAM, Aja t-tap
Old 05-12-2020, 02:39 AM
Farhoof's Avatar
Farhoof Farhoof is online now
Default Re: Premiere Pro AAF import Issue
Fastest and easiest is to export as OMF, copy all media to folder (with plenty handles). Don't embed audio to circumvent the 2GB limit.
AAF's from Premiere hardly ever work around here, and even if they do work I'll never be sure I received everything I needed to receive and sometimes I would spend more time getting an AAF to work then working on the actual project, so these days I go for the ancient omf export.
Unless you are using Protools 2020.3, because omf import is bugged
Old 05-12-2020, 04:43 AM
EarHole EarHole is offline
Same. Keep it simple.
Old 05-12-2020, 12:30 PM
Thanks guys. A benefit from working with OMF/Premiere is that the workflow doesn't change filenames, right?
To my surprise this time a workaround Premiere 13.1.0 AAF --> Davinci Resolve 16 AAF --> PT Ulti 2020.3 - seem to worked out fine for us.
(Filenames of Production Audio changed to name of the video files, but scene/take metadata being kept)
It seems like Davinci Resolve made an improvement on AAF exports, although the Picture Editor said, both the "Avid" & "Pro Tools" Delivery Tab did not work. The regular Edit -> export AAF worked fine with an embedded 12GB AAF
Old 05-13-2020, 01:21 AM
noiseboyuk noiseboyuk is offline
Here's the quicksheet of notes an editor made for me to pass on after (another) troubled Premiere production. His final para I think was critical.
In terms of exporting AAFs, I just did the following:
File > export AAF > check ‘’breakout to mono’’ ENABLE and then everything is as it should be.
If you want to play with the available handles you can click on the dropdown menu next to ‘’Render’’ and change it to ‘’Trim audio files’’ after which you can input your desired handles on the embedded media.
The thing to be careful with is how you treat your audio in your edit, DON’T MERGE CLIPS, we synced the audio and video by creating multicam clips, then at the end of the edit we had to ‘’flatten’’ all the audio (and video) in the sequences before exporting the relevant files - this is done by highlighting al the multicam clips in the sequence, right clicking and going to ''multi-camera'' and clicking on ‘’flatten’’. This changes the synced audio from a synced clips to its original audio source and therefore is the correct file to embed in the AAF.
If you want to go down the rabbit hole, these threads howl pain:
http://duc.avid.com/showthread.php?t=394167
http://duc.avid.com/showthread.php?t=389425
I found working with standard EDLs via EdiLoad the most painless solution for a whole series that used PP.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2020 Ultimate; W10 Pro; i7 7820X; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
HTML code is On
Sound Missing in Premiere AAF, OMF Import imjtblanton Post - Surround - Video 3 10-30-2018 09:04 PM
OMF import from Premiere cs6 into PT 10 problem bebeuriarte Windows 3 09-28-2013 03:06 PM
Import audio from Premiere Pro 2.0 Flaf Post - Surround - Video 0 01-06-2007 11:31 AM
AAF Import from Premiere FlorianE Post - Surround - Video 6 07-28-2006 06:24 AM
Premiere export - Pro Tools import Stig Eliassen Post - Surround - Video 8 10-27-2005 09:04 AM
