Old 07-14-2004, 11:27 AM
tim carter tim carter is offline
Default Volumes Unsuitable for Playback
It seems while trashing preferences (which I've never done before) I have really screwed something up... when I went to open a session the 'disk allocation' popped up and asked to check it.. I did and it says 'none' under the root media folder... when I check ok the session opens and the audio files are not there.. the window reads 'the files are on volumes unsuitable for playback' it then asks 'would I like to copy them to a suitable volume' .. when I check yes the 'Choose Folder' appears with the audio files 'blued' out.. I cannot hi-light them to bring them up... any thoughts on what to do.... every session on my hard drive and my external drive is like this. I really need some precise directions on getting this back...Thanks for the help... tim
Mac G5, 10.5.8, 2 GB, Rosetta 800 w/X-HD Card, Control24, HD2, PT's 8
http://carterbrothersband.com/studio.cfm
Old 07-14-2004, 12:00 PM
Default Re: Volumes Unsuitable for Playback
Open the Workspace Window in Pro Tools 6.x and in the A (Audio) column - make sure the drive is set as a Record drive.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 07-14-2004, 12:09 PM
I am having trouble finding the Work Space.. how do I get to it? Thanks..tim
Old 07-14-2004, 12:14 PM
Which version of Pro Tools are you running?
Rail
Platinum Samples
Old 07-14-2004, 12:40 PM
6.0... sorry I did find my workspace, under the 'A' it is in Playback and under the 'V' is in Record.. is this correct? Thanks again, tim
Old 07-14-2004, 12:49 PM
ok... so I have my audio files back. Thanks soo much Rail. I'm still wanting to know what should be selected under 'V'.. tim
Old 07-14-2004, 01:17 PM
V is for Video... I keep mine to Playback.
Rail
Platinum Samples
Volumes are unsuitable for playback mylar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-04-2005 03:55 PM
Volumes Unsuitable For Playback?? rmccam Pro Tools TDM Systems (Mac) 1 06-16-2005 12:15 PM
Volumes Unsuitable For Playback?? rmccam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-16-2005 10:22 AM
Warning: Volumes unsuitable for playback Scott Nelson Tips & Tricks 2 02-04-2005 07:07 AM
Volumes unsuitable for playback? dmm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-21-2004 11:39 AM
