Old 08-09-2020, 09:16 AM
xy44 xy44 is offline
Default Bounce feature
Hi All.
Sadly my old ProTools PC died. so a new one is now firmly lodged in the studio and all is well!.....protools never ran so good! : )
well.. one small thing that's got me a bit puzzled is the the old midi drag to audio track bounce thing. - for some reason it now takes a very long time to do.. (runs max at about 4x the speed of normal. - it used to be super quick on the old PC. - so im thinking is there a ninja hidden setting somewhere im not seeing, or something other?
just putting it out there for you tech heroes.
Cheers
A
Old 08-09-2020, 09:48 AM
Default Re: Bounce feature
Hmm.. a LITTLE bit more info would be needed here...
Old 08-09-2020, 10:55 AM
Yeah Fair doos!..
ok so, for example the track Im mixing right now. has a lot of midi parts... now happy with how it all sounds to midi, so want to commit (bounce) to an audio file, so i can then mix. - and free up CPU, plus have a backup of the midi for if i screw up later on!. - ok so nothing new here really.
The way Ive always done this is... simple Drag the midi data to a new audio track in protools (stereo track) - and it used to print it, but very fast!. - this was on my old PC with mechanical HDs
Now ive super dooper SSD fast things. and protools loads/runs like a ninja.. apart from the bounce.. where it just takes a long time.
ex:- it used to be pretty much instant for a 3 min track.. - Maybe 15 sec wait or so...
now.. it takes about 2 mins.. still faster than real time. but a lot LOT slower than it used too.. - sort of gets anoying when I have like 50 of these to do! :/
Even simple midi edits (no matter how long it is) - soon as I drag I know Ive a big wait ahead.. as used to be pretty much instant.
I really cant explain it better than that! :)
Old 08-09-2020, 10:57 AM
So you are trying something else than everyone else is doing, such as freeze track?
Old 08-09-2020, 11:19 AM
no.. freeze track in the same, but you press a button and have less control. - but still its exact same render times/bounce times.
It matters not. Freeze/Commit/Drag its all the same. - its just extremely long for what it needs to be.
and I don't know what it could be, not sure if a windows thing, or a PT thing. or somet else completely!.
Old 08-09-2020, 11:21 AM
I'm sure you have double checked that your system is compatible to begin with...
Old 08-09-2020, 11:34 AM
yup as its a certified protools PC :)
Old 08-09-2020, 11:35 AM
Well if subtle hints are not enough... then well please could you share your OS and PT version so some of us could have a clue of what you are using?
Old 08-10-2020, 04:03 AM
Sure
very latest windows OS. and also the very latest PT version.
(im not tech PC savy so not sure how to check all these things.)
Old 08-10-2020, 10:13 AM
DontLetMeDrown DontLetMeDrown is offline
Of course it’s going to vary depending on which VI you have loaded. A simple monophonic synth should be much faster than say, an East West library. Also song length and sample rate will come into play.
Bounce feature suggestion spliffonius Pro Tools 9 1 05-12-2011 02:45 PM
Bounce to Quick time new Bug / Feature ? SOUNDDECISION Pro Tools TDM Systems (Mac) 1 09-11-2009 09:06 AM
Feature Request: Quick Bounce! Delta Dreams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 04-17-2007 11:24 AM
Feature Request: Bounce to Disk... Michael Coyle General Discussion 9 06-25-2003 09:25 PM
Bounce question (is this a bug or a feature) doug sjostrom General Discussion 2 06-22-2001 02:47 PM
