Old 04-17-2018, 04:51 AM
TAFF TAFF is offline
Default 2018.4 major pan bug
Anyone getting panning issues on 5.1 tracks. Getting the Front and rear pans wrong. I pan something left front to Centre to right front and the automation doesn't playback and stays right and the rear automation in the pan window moves instead.
Old 04-17-2018, 04:58 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: 2018.4 major pan bug
This post will be better in the post and surround forum? i'll move it there for you.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-17-2018, 05:31 AM
It's got a yellow "position" dot instead of red if that's a clue. Pan SAFE Mode was on on a system that it was tracklayed on. Never know that existed.
Old 04-17-2018, 06:14 AM
its2loud its2loud is offline
Yellow means automation in is either off or suspended. Check you automation enables window.
HTML code is On
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 04:41 PM
Reverting from 2018.3 to 2018.1 jamesleonard Pro Tools 2018 11 03-12-2018 05:21 AM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 05:01 PM
beginner in pro tools needs major help, 7 major questions... heidib123 Getting Started 18 07-06-2017 06:29 PM
Dubbing Major Pix, Major Problems BigBobMXMan Pro Tools TDM Systems (Mac) 0 07-15-2001 01:43 AM
