Old 04-10-2018, 10:15 AM
Roger Stauss Roger Stauss is offline
Default Sync HD going..slowly
Our Sync HD unit is 18 months old. About 3 weeks ago it lost contact with ProTools a couple times. Then yesterday complete failure.
I benched it, It booted ok, then about an hour later the display flashed a few time and filled with 8's.
Before I pull a repair ticket, anyone else have this problem?
It's running fine on the bench now...It's been 2 hours.
I did do a re-set to factory default.
PT 12.8, HDx, Mac OS,
Old 04-10-2018, 09:07 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: Sync HD going..slowly
Power supply?
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 04-11-2018, 04:20 AM
kkfaudio kkfaudio is online now
Mine is unhappy when in a warm rack.
Removed from rack and it’s been stable ever since.
Kevin Ferrier
Audio & Sound Design
www.jaxxcreative.com
Old 04-11-2018, 04:31 AM
Thanks. It was in a warm rack. I'll give it another day running on the bench.
Old 04-11-2018, 05:40 AM
Norad155 Norad155 is offline
I second that... I added a blank rack space above all mine and they work fine now.
I never got crazy 8's... but they definitely freaked out.
IMDB
Old 04-12-2018, 10:45 AM
lucienpalmer lucienpalmer is offline
I have the same issue. If the ambient temp of my closet gets above 90 degrees, the Sync HD starts connecting/reconnecting.
I also fixed it by addidnt a black space above and below, but I still have to add a fan to increase air flow around it.
In a funny side note, my old equipment closet had much worse airflow and caused a huge problem with the Sync HD. I placed a meat thermometer probe on top of the Sync, and set its remote to alert me at 105 degrees. When the surface of the Sync hit that, I knew it was time to open the closet and take a break.
Thankfully I have AC in the new closet.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 04-12-2018, 12:58 PM
Originally Posted by lucienpalmer View Post
I
A meat thermometer! Good idea. I should have one around here somewhere. I raise beef...for fun.
Here's what I found:
1. The unit seems to runs much cooler on the bench.
2. It heats up when connected to the HDx card, loop sync Etc. It gets hot!
3. I did provide a rack space above and below.
4. I reset the firmware. v2.2.1
5. Reset to factory settings. Then reset my parameters.
6. Running fine with no clients here.
Thanks everyone for the help..including the Avid guys in support.
Old 04-12-2018, 01:35 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
I ran into the same problem before I placed it in the machine room with dedicated air conditioner.
And even though I have no problem now I think a solution to free space rack above and below of Sync HD is not an engineering solution.
Avid should investigate and say clearly what cause this issue and how to fix it.
But yes, I am getting rhetoric again...
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
HTML code is On
pro tools 11 works slowly vinagrepuro Pro Tools 11 2 01-08-2015 05:15 AM
A possible tip if PT is loading slowly ronwasserman Pro Tools TDM Systems (Mac) 1 05-13-2011 01:52 PM
Pro Tools going really slowly, then nothing. sssaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-07-2007 09:09 AM
PT 6.2.3 OMF opening SLOWLY Rob Macomber Post - Surround - Video 0 04-25-2004 06:46 AM
6.0.1 seems to slowly get less stable Spyder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 06-17-2003 01:02 AM
