  #31
Old 03-29-2018, 08:29 AM
quadraphonics quadraphonics is offline
Default Re: LtRt AAX plugin
Most places I know of are taking 2.0 Stereo (LoRo) instead of LtRt (1 or 2)these days.
Randall
Originally Posted by marsian View Post
Update...
I managed to create a session to encode Fullmix/ DX-Stem/ SFX-Stem and MX-Stem at the same time to LtRt (you have to do it in realtime).
All you have to do is configure inputs (5.1) and outputs (stereo) in the Dolby Renderer application as needed and the send- and return-plugins in the ProTools session.
I recorded on new tracks and LtRt are in sync witch the 5.1 tracks!
Cheers
Maik
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
  #32
Old 04-06-2018, 06:39 AM
yanos yanos is offline
Randall
And they are right…
Indeed it works with Dolby Atmos Production Suite but it's a bit tricky, there is a delay (less than one frame) while you rec the file inside Pro Tools and you can't decode the LtRt.
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 12.7.3 - Ram 64G - PT Ultimate 2024.3.1 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround)
  #33
Old 04-06-2018, 01:14 PM
marsian marsian is offline
I think this thread is about which plugins can be used to encode an LtRt, not about if LoRo is better, right?
Cheers
Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
  #34
Old 04-07-2018, 07:25 AM
Cheers
Maik
I think you waste your time by answering this way.
And in this thread there were already opinions about LoRo and LtRt.
Ok?
  #35
Old 04-07-2018, 07:34 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Antonis
I have a Dolby Surround encode /decode tdm plug for sale if you still have a tdm rig lying around
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
  #36
Old 04-07-2018, 12:07 PM
Watagushu2013 Watagushu2013 is offline
Have any of you tried waves DTS neural processor plugins? They do LtRt, stereo and they have also decoding plugins.
  #37
Old 04-07-2018, 01:37 PM
Personally no
I always find that what ever plugs Waves do, someone else does way better, usually because Waves imitate and make poor copies, i.e. Waves WNS and the Cedar DNS One.
cheers
BAFTA member
IPS member
  #38
Old 04-08-2018, 10:54 PM
I tested it. It sounds but you get a 5.1 track with four channels of silence. Not a stereo interleaved track.
For me too much workflow to get stereo and un-necessary disk space used (and you could accidentally get wrong when you select the L and R channels of the 5.1 to export a stereo interleaved wav).
  #39
Old 04-09-2018, 06:12 AM
I use it with no problems at all. You just bounce a stereo sub path and your done. Its actually the same principle on Neyrinck and minnetonka.
HTML code is On
LtRt Question sonichead Post - Surround - Video 8 09-03-2013 01:45 PM
5.1 to LtRt zzstation Post - Surround - Video 3 05-25-2012 12:19 PM
Neyrink LtRt plugin: container lululu Post - Surround - Video 4 08-12-2011 09:06 AM
Some LtRt quesitons Newpostguy Post - Surround - Video 11 08-18-2010 06:08 AM
How do i create an LtRt mix from 5.1? Andy Hay Post - Surround - Video 18 11-08-2004 09:46 AM
