Old 08-14-2013, 07:27 AM
mingojr mingojr is offline
Default "Can't get audio from the drive fast enough" -9073
I'm having the popular "Can't get audio from the drive fast enough" -9073 error in Pro Tools. This happens on bouncing and sometimes just playing the track. Always happens on 100 track songs, and frequently happens on even 30 track songs. If I move the session to the internal hard drive it then works fine.
Has anyone had any luck beating this problem??? I've heard about replacing firewire kext files to an older version (10.5) but i can't find those files anywhere. If anyone has them it would be great if they could share them.
Here are my specs.
Mac OS 10.6.8
Pro Tools 9.0.6
iMac 2.5 GHx i5
12 GB RAM
External Lacie 7200rpm 500GB Firewire 800 drive with 75% free space.
Time Machine turned off
Pro Tools Open ended recording set to 20 minutes.
Deleted my PT preferences, ran a kExt utility program, repair permissions on system drive. Haven't tried defragging the external drive but do have a Defrag program if people have found that useful.
Any help would be greatly appreciated.
Old 08-14-2013, 07:34 AM
Meads Meads is offline
Default Re: "Can't get audio from the drive fast enough" -9073
Is your Lacie a USB drive?
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 08-14-2013, 08:41 AM
Sorry should of mentioned it's a Firewire 800 drive.
Old 08-14-2013, 09:36 AM
Did you format it Mac OS extended (journaled)?
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 08-14-2013, 09:53 AM
bradch00 bradch00 is offline
Is your interface (MBox 3?) daisy chained with your Lacie and (if so) have you tried changing the order?
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 08-14-2013, 09:56 AM
Yes...
It does it on another disk as well that is formatted MS-DOS (FAT32)...but that one only seems to happen on really large sessions.
Old 08-14-2013, 09:57 AM
The mbox is on it's own hub through a thunderbolt to firewire adaptor.
The hard drive is on the firewire on its own but there is another hard drive daisy chained to it.
Thanks
Old 08-14-2013, 10:13 AM
And describe what is in your session, sample rate, how many audio tracks? plugins, VIs etc.
There are no VI samples on the external drive right?
What is the other hard drive used for and can you remove it to see if it improves things?
Does this happen in other sessions or just this one? Can you try creating a new simple session with not much in it (import content from the existing one for a test) and see if it happens to that.
Beside marking the entire lacie drive private to avoid Spotlight indexing, you can also try marking all other drives you have as private as well. And have you done all the other systems optimizations? including disabling time machine, bluetooth, WiFi, etc. be sure to do every last one for now, at least while you are debugging things.
BTW you should never use FAT-32 as a Pro Tools filesystem, it is not supported/known not to work/cause problems.
Old 08-14-2013, 10:35 AM
Thanks for the response session is 39 tracks include buses master, midi tracks, instrument tracks, audio tracks, etc. It's 44.1/24 bit. It has Omnisphere, Kontakt for Vst. Plugins are Lo-fi, Fabfilter Pro-Q, CLA-76, CLA-2A FabFilter Saturn, H-Delay, SSLComp, FabFilter Pro-L, NI RC48 verb, EQ7B, Soundtoys PanMan...That's it.
I'm not sure what VI samples are...but i'm guessing no because the only things on the drive are Pro Tools sessions.
I unhooked the other hard drive and it didn't seem to change anything.
It happens in a bunch of different sessions.
I don't know what you mean by marking the drive private but i'll google/look into it.
Time Machine, wifi are off. Bluetooth is on because of a wireless keyboard.
Thanks for all your input!
Old 08-14-2013, 10:43 AM
Marking the drive private is how you normally disable timemachine indexing. Describes in the standard optimization instuctins. If you have not doen that how have you disabled time machine?
Oh you are running Kontakt. That is a mother of sample based VIs. The samples used by Kontakt should normally be on the boot/system drive or on a separate drive used for samples (never on the audio/session drive). Can you confirm where exactly they are
Do all sessions you tried have Kontakt in them? Try disabling the Kontact plugins in a session. Does that help? Try opening a session with all plugins disabled File>Open>... while holding down the shift key.
What are all your playback engine dialog panel settings?
Try creating an empty session and importing a few basic audio tracks into it. Does that work?
"DAE can't get audio from hard drive fast enough..." jervin Pro Tools TDM Systems (Win) 17 06-13-2014 08:04 PM
"DAE can't get audio from the drive(s) fast enough. Help!! Schumannz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 09-22-2012 10:38 AM
PT 10: "Can't get audio from the drive fast enough" mr.armadillo Post - Surround - Video 18 02-03-2012 08:43 PM
"DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or iminzayne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 04-15-2010 10:28 PM
DAE error -9060 & -9073 "disk frag or too slow" with new LaCie FireWire Drive! mikerica101996 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-19-2003 08:56 AM
