Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 10-01-2012, 01:28 PM
robo456 robo456 is offline
Default Triggering "step-thru" loops with Roland TD-4, SPD-S, and mac possible?
Hey guys... I've been searching thru the forums, "googling", and youtube, but I haven't found exactly what I'm looking for. Here's my current setup:
Roland TD-4 (connected to mixer and Macbook via roland UM-1G midi interface)
Roland SPD-S (currently connected to mixer)
I use Logic 8 and the Addictive Drums package, as well as Garageband on the macbook. I have no problems using the SPD-S in wave or patch mode for triggering loops, but only in a "start/stop" or overlayering fashion. What I'd really like to be able to do is trigger a "step-thru" type loop like my friend's TD-20. I'm not sure if I'm using the right words; basically, you hit one pad and each time you hit it, it steps thru the loop, one note at a time. There's alot of videos on youtube from the NAMM events that show it, but it's always on the newer 'brains'. Here's a video of Johnny Rabb on the TD-20KX kit; perfect example is at 1:22 (melodious) and 2:10 (neotype) https://www.youtube.com/watch?v=oMF1WzRKus4#.
I really don't have the money to drop to get a new drum set, but I wouldn't be opposed to pick up ProTools, Ableton, or a similar program that might help out.
Has anyone ever tried to do this, or are there any forum posts I might have missed?
Thanks in advance for any info!!
**EDIT**
From more searching, Roland uses the term "Tap Sequencing" and from what I can tell, it was available on the TD6, 8, 12, 20, and now the 30.
I've gotten closer with looking at Ableton Live videos/guides about "slicing to MIDI" but still not quite there...
--rob
Old 10-05-2012, 06:36 PM
Default Re: Triggering "step-thru" loops with Roland TD-4, SPD-S, and mac possible?
You might load the audio of your loops into Structure Free and assign each to a single midi note value that corresponds to pad midi note value in the Roland brain
Old 10-06-2012, 10:43 AM
Thanks for the reply.
From what I can tell right on the surface, I'm not sure if it will handle multiple "notes" per pad, which is what I'm looking to do (basically, hitting one pad in sequence will give you C, D, E, F, G, A, B, etc)
I'll definitely take a look more in depth at the plugin tho, and see what it can really do.
--rob
"Step phaser" effect on Eleven Rack? julyen Eleven Rack 3 08-18-2011 10:24 AM
NCT AudioFile2--->step 1. Then "coreflood" hack aka21stCentury General Discussion 2 04-14-2011 06:24 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
"Beats working". drum loops from Abbey Road midiman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-21-2003 01:55 AM
Monitors... "DS90" (Roland) VERSUS "MSP5" (Yamaha) Renan General Discussion 2 12-26-2002 03:36 PM
