Old 08-15-2011, 07:43 PM
julyen julyen is offline
Default "Step phaser" effect on Eleven Rack?
I'm trying to reproduce an effect called "step phaser" from an effect processor I used before (BOSS GX-700). I searched in many places but couldn't find information even about how would I get this effect.
Obviously if it can work with the built-in effects that would be great :)
Thanks!
Julien
Old 08-16-2011, 03:59 AM
blewis blewis is offline
Default Re: "Step phaser" effect on Eleven Rack?
Something like this?:
http://www.google.com/url?sa=t&sourc...kdLZtvpiLprWow
Generally these type of effects are created by having some period control signal change an effect parameter on the fly.
On a synthesizer, the is a periodic control signal generated by something called a LFO - Low Frequency Oscillator. They can be set to sine waves, square waves, and something called "Sample and Hold" - which sounds like a random sequence.
You can also change parameters on effects with some kind of pattern generator like a MIDI arpegiator.
Alas, the 11R doesn't have any LFOs or pattern generators. However, you could configure a synth to send it's LFO into the 11R as a MIDI CC. The 11R can change up to 4 amp/effect parameters at a time from the same MIDI CC.
Old 08-16-2011, 01:37 PM
Benoni's Avatar
Benoni Benoni is offline
As said above, it would be helpful to know exactly what you mean by "Step Phase" because I have heard several different Step Phase effects, some are more like a ring modulator, while other employ pitch shifting, and others are just random noise, and most have several options for a combination of effects.
So what exactly are you referring to?
The above video?
or
http://www.youtube.com/watch?v=6FZprd9kQk4
or like the Hyper Phase from Digitech
http://www.digitech.com/en-US/products/hyper-phase
Click on DEMO and listen to the STEP example.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 08-18-2011, 10:24 AM
Thanks for the replies!
The effect I talk about is really similar to the Boss PH-3, not surprisingly since it was a Boss effect processor. I will take a look at that pedal next time I stop by the music store.
It is indeed similar to what can be done with an arpegiator, and a bit "bubbly" if that's a word. With a variation in the pitch and separate notes going up and down. I will have access to this older module this week-end and will bring it with me so I can record it if it can help.
Would it be possible to use the arpegiator of Xpand in ProTools to play around with the concept? I'm not sure which parameters I should try to vary? Or similarly, use the pedal on my MIDI foot controller?
Thanks!
Julien
Eleven Rack not recognized by Macbook Pro as a "Sound" device spc777 Eleven Rack 3 09-10-2015 09:11 AM
Eleven rack expansion pack serial "already activated" pieroft Eleven Rack 31 12-30-2011 04:37 PM
Eleven rack (11R) slow booting past "setting up midi" Edleigh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-25-2011 09:44 PM
Do I need the "Transfer Ownership Audio" form to sell my Eleven Rack? acmost General Discussion 5 04-16-2011 12:07 AM
Eleven Rack "Unable to locate Digidesign hardware" efisch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-07-2011 03:18 PM
