Alt+[ keyboard shortcut problem
When I try to use the above shortcut "Alt+[" to play an Edit Selection it plays the Timeline Selection instead (both are in different locations in Pro Tools).
And if I try to use the "Alt+]" shortcut (wich is supposed to play the Timeline Selection) it just doesn't do anything - nothing happens. The same occurs with all the other shortcuts using the "[" and "]" keys but as long as I can say all the other keyboard shortcuts are working properly in my system. Please, help me. Thanks in advance and sorry for my english. |
Re: Alt+[ keyboard shortcut problem
make sure that your keyboard is set to English. That is my only big idea.
Hi, Kirby
Thanks a lot I had already tried that with no success. But I finally got the answer. All I have to do is use the "´" key on my computer keyboard and it works as if it was the "[" key - and, as a said before, the "[" key works as it was the "]" key. I'm from Brazil and all keyboards here have a "´" key and also other accentuation keys I think english keyboard doesn't - so that's the orign of the problem. Thanks a lot again. I'm new to Pro Tools and I'm learning a lot from this forum. Happy new year! ***** My system Self Built PC Motherboard: Asus P5Q Deluxe Processor: Intel Q9550 Memory: 4 GB Kingston HyperX DDR2 1066 PC 8500 Dual Channel HDs: 4 SATA2 500GB Western Digital WD5000AAKS Power Supply: OCZ 850W GameXStream CPU Cooler: Noctua NH-U12P DVD drive: SATA Pioneer DVR-216D Case: Chieftec BA-01B-B-B Case fans: Noctua NF-B9-1600 & Noctua NF-S12-1200 Video card: ECS GeForce N8600GT 256MB DDR3 Firewire card: SIIG NN-440012-S8 Floppy drive OS: Windows XP Pro Port SP3 Internet Explorer 6 Pro Tools Digi 003 Factory Pro Tools LE 8.0 |
Prime for Playback/Record keyboard shortcut problem | David Hardie | macOS | 1 | 10-21-2012 05:47 AM |
iMac Keyboard Shortcut problem | Drafter | macOS | 10 | 01-14-2011 08:44 AM |
Keyboard shortcut problem | idris | Pro Tools TDM Systems (Win) | 1 | 02-15-2009 09:51 AM |
protools le7 keyboard shortcut problem | joen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-15-2006 01:53 PM |
keyboard shortcut problem(s) | buddyerkin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 01-07-2005 09:11 AM |
