Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
  #21
Old 03-31-2015, 04:23 PM
maunaloa maunaloa is offline
Default Re: No Parameter Feedback in 11.3.1
If you see blanks on the Channel Encoder Displays on an S3, make sure you haven't installed Eucon AND the Eucon control panel (in a different folder after unzipping). After I uninstalled both and reinstalled only Eucon, the Channel Encoder Displays behaved properly.
ASRock X99 OC Formula mobo, Win 8.1 x64, PT HD 12.1, i7-5960X CPU, 32GB G.Skill 2133 RAM, Intel 750 PCIe SSD boot drive, ASRock TB2 AIC, Sonnet Tech III-D with 2 HDX cards on TB2, Omni, HD I/O, S3, Artist Transport, SSDs and spinners, AMD HD 7990 GPUs, 2 HP ZR30w panels on DP.
  #22
Old 04-01-2015, 03:26 PM
made made is offline
You don't experience the issues like ...
- wrong channel encoder mappings
- plugin window doesn't follow
- faders stop working
- "Save Softkeys" message on shut down
etc
on Windows?
All smooth and working?
i7 3,39GHz, 32GB, PTHD2018.12, OS 10.12.6, S3, Transport, (EuCon 19.5.1.44)
LIO
AJA XT-Express
Reaper 5.97, Fireface UCX
MacbookPro i7 PTHD2018.12 10.12.6
  #23
Old 04-03-2015, 02:44 AM
Made, no ... not all smooth yet, but power-cycling usually fixes the weird behavior, and always fixes dead faders. I also launch Eucon manually. I have far fewer problems if I don't use third-party plugins. Kontakt 5 and Omnisphere are the worst offenders. I have had problem-free sessions after manually launching Eucon and using no third party plugins.
Here's the strangest part. The S6, S3, and Artist series all share Eucon, but each control surface has a different set of Eucon-related problems. For instance, the S3 control surface banking losing sync with the PT mix or edit window is mainly (TMK) an S3 problem. Since the S6, S3, and Artist control surfaces are different, the control surface/Eucon programming is different for each control surface, so IMO the S3 problems lie in that programming. My guess is that the assignment tables that Eucon uses are being corrupted by rogue plugins. The tables are different for each different control surfaces, so the problems are different.
See if you have fewer problems if you manually start Eucon and avoid third party plugins.
  #24
Old 04-04-2015, 12:27 AM
Made, see Kyle's sticky about the release of EuControl 3.2.2 and Workstation 3.2.2, and the bugs it fixes (e.g., dead faders). I've installed the updates... PT follows bank switching, and haven't had a dead fader (yet). However, the update does not fix bank following in PT11.
parameter assignment + artist mix b.riesel Artist Series 0 01-21-2014 09:48 AM
Sysex Parameter Dump Rob0214 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-18-2008 05:41 AM
HELP I can't open a session because "parameter... shawnv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-14-2004 01:09 PM
multiple parameter changes-Mix drenched Pro Tools TDM Systems (Mac) 1 09-05-2001 12:18 AM
multiple parameter changes -Mix drenched 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-04-2001 10:59 PM
