Will Pro Tools work with
I am about to switch from using Logic Pro 9 with my mixing desk a Midas Venice F32. To a new computer and Pro Tools 11 and before i buy anything want to make sure it will work
The New computer will be a 21.5-inch: 2.9GHz Imac with 16gb ram and i will be buying Pro Tools 11. Will i be able to just plug in the Midas using a Firewire to thunderbolt cable and Pro Tools 11 just work with it like Logic Pro 9 did? |
Re: Will Pro Tools work with
Yes it should work. You will need to install the device driver just like for Logic. The proof here but is not asking others it is trying out the Pro Tools 11 trial available on Avid's web site. You need an iLok2 license dongle (PT 11 wont work with older iLoks) to put the trial license on. Available from Amazon, Sweetwater, many music stores etc. Do not start the time limited trial until you have the Mac setup ready to go. Make sure the Mac meets the minimum system requirements, including a separate audio-spec hard drive or SSD for audio/session files and (unlike logic) you have to read and follow the installation instructions, including doing the recommended systems optimizations.
The big question for any use of Pro Tools 11 now is what plugins you need/want to use and are they in AAX-64 bit (aka AAX2) format for use in Pro Tools 11. I would always go for the 27" iMac for increased screen real estate. Also I would only ever consider buying an i7 processor based Mac for Pro Tools (the 2.9 GHz is a i5). |
Sorry for the double posting.
Few more questions, will i need the Ilok when i buy the full version, is there not just codes in the box? Also what do you mean separate audio-spec hard drive or SSD for audio/session files the imac will have 1t hardrive and i also have a 1t external hard rive. And doesnt an i5 processor meet the requirements for pro tools |
You need the iLok for the trial and the full license. The Installed software is the same. Once you have the trial installed you can purchase a full license online and download it to your iLok. If you buy a boxed version it will come with another iLok2.
If you or others you work with play guitar a great way to buy Pro Tools Eleven is to buy an Eleven Rack interface/guitar processor which includes PT 11. Ditto if you wanted a small more portable interface consider an Mbox Pro Bundle. |
Thanks, I just want the software for now got all the hardware I want just really wanted to know if the computer I was buying would be ok. As looking at the requiments for pro tools I thought just upgrading it 16gb of ram would be enough to use pro tools
So i5 not ok though
You need to read and understanding the Pro Tools 11 disk requirements yourself. Telling us you have any "1TB" drive is not enough. What exact make/model/spec drive and how us it connected to the Mac?. Avid have added support for USB 2 external drives to PT10 and 11 but I would still avoid these as too slow. For external drives FW800, USB 3 or Thunderbolt would be my choices--but those drives need to also meet the 7200 minimum rpm (or be an SSD--and if buying an SSD I am pretty fussy about using a Samsung 840 Pro, recent Micron or maybe a few others, not all SSDs are created equal). And if FW the drive/interface box must use an Oxford controller chipset. Avoid putting a FW800 drive in the same bus as your FW interface/console. |
I second the i7 recommendation.
i7...i7.....yes, i7. You will NEVER be upset about having MORE power.....
+1... i7.
Does M box 3 work with Pro Tools 8? | thekid250 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-01-2012 11:51 AM |
Pro tools se doesn't work..help! | bonnex | Pro Tools SE and Essential (Mac) | 1 | 02-22-2011 02:24 AM |
will pro tools work on new x58 | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-18-2009 07:20 PM |
Pro Tools 4.3.2 won't work with Mac OS 9.2? | Ter | Digidesign Hardware & Software | 1 | 01-02-2002 07:49 AM |
