Closed Thread
Old 09-23-2022, 10:42 AM
dbcn dbcn is offline
Default 2022.7 - AudioSuite plugins not working? [SOLVED]
Hi - I just upgraded to 2022.7 and installed all the things via the AvidLink - I'm on Monterey 12.0 with a M1 MacbookPro - I noticed that when I select part of a voice track, and go to AudioSuite > Other > Normalize and click Render, there is no change to the audio. If I select another AudioSuite plugin, and click Render - also no changes, but if I preview the selection using the plugin window, I hear the affected audio... any tips...?
Old 09-23-2022, 11:42 AM
Default Re: 2022.7 - AudioSuite plugins not working?
Make sure the "Use In Playlist" button is checked.
Scott Gatteño
Old 09-23-2022, 01:07 PM
nednednerb's Avatar
nednednerb nednednerb is offline
Yep.... Sometime in last couple updates I noticed my audio in the playlist did not update. I happened to notice a clip was indeed created in the clip list.
Aha! My brain went. I glanced around the plug-in and indeed Use in Playlist was de-selected. Between a "prefs" trashing or a recent update that overwrote this switch, this happened.
After switching back to Use in Playlist, future uses of Audiosuite remember the setting and replaces my clips on render.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 09-24-2022, 02:38 AM
thin ice thin ice is offline
This happened to me when I updated to 2022.7 recently. This is an odd default to have.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 09-28-2022, 12:40 PM
Thx originalscottyg - that was it - once I activated 'Use in Playlist' it rendered as expected.
Closed Thread
Audiosuite plugins crashing Protools 2022.6 on MAC M1 Max paulo m Post - Surround - Video 10 10-21-2022 02:30 PM
Audiosuite plugins suddenly don't work [solved] vsrecord Pro Tools 2018 7 04-12-2019 12:09 PM
Time Shift plugins not working [solved] aduesing AAX Plug-ins 3 01-30-2017 07:40 PM
Audiosuite plugins not working... beasleymusic Pro Tools M-Powered (Win) 0 10-14-2010 05:40 PM
audiosuite plugins stopped working baselinejumper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-17-2006 08:32 PM
