Command 8 Fader issue. Can anyone help please?
Hello. This is my first post, so I'm not too up to date with etiquette.
My Command 8 (4 years old) has developed a little issue. The faders jump around when I switch the unit on (whether I'm running Pro Tools or not). All I have to do is pull the faders back down and it's good to go. However, when I am in pro Tools (10,11 or 12) and I page through the tracks. Going forward is fine, going back through the pages, the display on my Command 8 and the faders 'judder'. I have already re-installed / re-flashed the firmware. Any help would be greatly appreciated. Ray. Boot issue : https://youtu.be/GSbSIgHNjgs Page issue :https://youtu.be/07kIFSP-OCI |
I should point out that when I have the 'switching on' issue, it is ALWAYS different faders that have the issues. Not the same each time.
Anyone?
If just like to say thank you for the huge help that you have all given me with this issue. It's so nice to know there is a warm, friendly community that is always there to lend a hand when us novices need guidance.
The quality of assistance I have had from this forum is matched only by the quality of assistance I have received directly from Avid. Breathtaking. |
Have you taken the base off and inside disconnected the faders blown the dust out then reconnected them. I've had this issue and that sorted it out for me.
PS this a great forum and there are lots of helpful people on here
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Hi Raoul23. Thanks for posting.
Yes, I have tried this. Unfortunately, it didn't work. The only thing I can think of doing is taking it to an Avid repair / service centre and having them look at it. Thanks for your time though. I do appreciate it. |
If you get them to sort it they will prob charge you a fortune I'd just buy another off eBay
Raoul Crane
Good advice^^^ but before you do that, I would open the unit and re-seat every connection you can find(actually unplug-replug each connection several times each). Why? because the Command8 is of a vintage that is similar to most 002 and Control24 units and those were pretty notorious for have wiring/connection issues. Spraying some De-oxit at the same time is also not a bad idea
albee1952 Thank you. Sound advice. I'll do this today. I have already tried this. I just unplugged and re-plugged the faders. This time I'll do every connection I can unplug, plus, I'll spray the contacts. I have some switch / contact cleaner and anti-static air cleaner. I'll give them a go. Thank you
Re: Command 8 Fader issue. Can anyone help please?
Did you get it sorted Ray? Is updating the firmware like the Pro Control? Where you just log into PT and it happens auto-magically?
Command 8 Fader Issue | howellette | Digidesign Hardware & Software | 3 | 05-24-2014 04:03 PM |
D-Command ES + Fader Madule Fader Problems | FedericoF | ICON & C|24 | 11 | 05-24-2013 04:27 PM |
FAder Issue D-Command | kd_special | ICON & C|24 | 9 | 07-10-2010 10:30 AM |
Command 8 Fader Issue | iron_aidan | ProControl, Control|24, Command|8 | 9 | 12-06-2008 10:49 AM |
'Fader Pack' and ProControl Fader order issue | Ciaran | ProControl, Control|24, Command|8 | 2 | 03-21-2005 11:58 PM |
