Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 10-04-2013, 07:26 PM
stog stog is offline
Default Software does not run: Unable to locate hardware
I am trying to run Pro Tools Express with Fast Track Solo. I have spent two days trying to make this work on both Mac and PC. Neither works. I gave up on Mac and went to my PC because tech support told me it would work then. On PC, however, I am getting, "Unable to locate hardware. Make sure your hardware is connected and turned on. Click "OK" when the hardware is".
#1: This product does not work on my Mac or PC
#2: The error message does not make sense. What hardware? My iLok is set up and plugged in. My Fast Track Solo is plugged in and transmits audio out to my speakers. (Why does the last sentence of the error message end as it does? "... when the hardware is" - WHAT? When the hardware is what?)
Has anyone else encountered this error message and if so, is there a fix?
What is the return policy on this? Can I return an opened box? I just got it two days ago.
Old 10-04-2013, 08:48 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Default Re: Software does not run: Unable to locate hardware
"... when the hardware is" should probably end with "connected".
You may have a defective product, but let's try and troubleshoot first with a few things you may or may not have tried yet...
1 - Have you tried installing the latest driver/firmware for the Fast Track Solo?
Available here:
Fast Track Solo Drivers
Linked from the main drivers page:
www.avid.com/drivers
2 - Have you installed Pro Tools Express 10.3.4, the latest version?
Pro Tools Express 10.3.4 Info & Downloads
Bruce Paine
System Details
Old 10-04-2013, 11:10 PM
Thank you for your reply. The latest driver/firmware fixed it.
Old 12-10-2014, 07:27 PM
Tizi805 Tizi805 is offline
I'm having the same issue… "unable to locate hardware"… this is driving me nuts. I have a mac running OS X 10.7.5. I have a Fast Track Solo with the Pro Tools Express software. I've gone through forums trying to find a fix but have not had any success… The drivers on the links above did not help. My Mac said that there were already drivers installed that were equivalent or newer/better. I really hope this isn't a waste of time and money… Help
Old 12-12-2014, 05:41 PM
Wow… i've been asking questions everywhere and can't seem to get a fix for this… I'm seriously considering just dropping this Fast Track Solo… I've been at it for about a good work week now… seems like a waste of time...
'Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o roland342 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-29-2012 09:01 AM
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on.. qillster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-31-2011 09:08 PM
Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on ytass Pro Tools M-Powered (Win) 4 11-25-2009 12:49 PM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
