Session saved on "transfer" only volume
My hard-drive crashed and had to be replaced. I re-installed Pro Tools M-Powered 8 (which I then upgraded to 8.0.1). When I tried to open a session that I had composed before the hard-disk crash, I got a message:
This session is saved on a volume set to "Transfer" only. If permitted, set the volume(s) in question to "P" (Playback) or "R" (record) in the workspace. Otherwise, choose OK to save a copy of this session and its media to a valid playback volume. I don't know why the C drive isn't a valid playback volume and I don't know how to set the volume to P or R. Any suggestions? Thanks! |
Re: Session saved on "transfer" only volume
G |
Thanks Greg -- worked perfectly!!
Greg, what if it won't work when you try to change the T to a P or R in the A column? I just got a new computer, windows 7 ...I have mbox 7.4....do I need to set up a diff drive for this to work? thanks!
I have the same issue starting a NEW SESSION, BUT, i changed the A-V volume to "R" in the WORKSPACE. NOW when I try to start a new session it says "GATEWAY is not an audio playback volume" I bought a external drive but I dont know how to change the settings I guess, PLEASE HELP
Session saved on a volume set to Transfer only? | alexanem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-17-2023 03:22 PM |
Help! "Session is saved on a volume set to 'Transfer' only" | nuemes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-06-2011 05:46 PM |
session saved in "Tranfer" Problem | Edson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-03-2009 03:19 PM |
Session saved on a volume set to "Transfer" only | Gilles D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-02-2009 02:19 AM |
The session is saved on a volume set to "Transfer" only... | fiddlecat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-20-2008 03:16 AM |
