Streaming bit rate etc
I understand going from 24 to 16 bit you need to dither. If you upload a 24 bit 48k do the streaming services knock that down to MP3s? if so do they automatically dither
Wow am I groovy or what |
Re: Streaming bit rate etc
There is no Bit Depth in mp3 or AAC. The encoding happens from the digital audio data, whatever that format is (16bit, 24bit, 32bit float). It applies its encoding algorithm based on the Bit Rate.
That means the higher the Bit Depth that you give an encoder the better, no matter if you create your mp3/AAC files yourself or upload to a streaming service that is doing the encoding for you. Here are some excerpts from Apple's "Mastered for iTunes" delivery requirements: An ideal master will have 24-bit 96kHz resolution. These files contain more detail from which our encoders can create more accurate encodes. However, any resolution above 16-bit 44.1kHz, including sample rates of 48kHz, 88.2kHz, 96kHz, and 192kHz, will benefit from our encoding process. Our encoders then use every bit of resolution available, preserving all the dynamic range of a 24-bit source file and eliminating the need for dithering Don’t provide files that have been downsampled and dithered for a CD. This degrades the file’s audio quality. And yes, Pro Tools is still not providing encoding for AAC (as was recently discussed on this forum)
Edgar Rothermich Author of "Pro Tools 2020 - How it Works" from the Graphically Enhanced Manuals (GEM) series http://DingDingMusic.com/ YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/ |
auto matching pull factors + frame rate + timecode rate | Dingo90 | Post - Surround - Video | 1 | 10-17-2009 04:16 AM |
Bit Rate/Sample Rate problem? The chipmunks? | bspro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 05:40 PM |
QT 23.98 video frame rate... timecode rate? | dopplah | Post - Surround - Video | 10 | 07-03-2007 05:28 PM |
OT: AAC streaming | Dale-c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-24-2004 06:31 AM |
OT:streaming mp3's | Tito Ricci Arballo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-13-2004 05:04 PM |
