Old 02-12-2021, 06:48 AM
Talisker Talisker is offline
Default Little Master Meter is not working
Not a big deal after all, but every once in a while the litte master meter next to the record button isn't showing any level. Definetely my fault but I can't figure out why. ???
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 02-12-2021, 11:38 AM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Default Re: Little Master Meter is not working
If you talk about the Output Meter component on the Edit Window Toolbar, did you check its Path?
When you right-click on the meter, a popup menu opens with a menu item at the bottom "Output Meter Path". You can set it to any of the available Output or Bus Paths.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 02-12-2021, 01:05 PM
It works most of the time, so that seems to be ok. I has to do with recording on my master print track....
Mono channel meter level lower than Master’s meter level Armando Pro Tools TDM Systems (Mac) 3 07-07-2019 04:51 PM
TL Master Meter Not Working taylor4814 Windows 3 12-20-2012 04:05 PM
Master meter? Tyderian Pro Tools 9 1 04-04-2012 01:07 PM
5.1 master, meter is LCR only? (PT's8) TCDet Post - Surround - Video 0 05-27-2009 08:04 PM
Master Meter clips Siegfried Meier Pro Tools TDM Systems (Mac) 7 05-29-2008 07:02 AM
