Deep Sleep and 6.4
I searched, but couldn't find an answer.
I have the small app that 'unloads' PT so the Mac will go into deep sleep. It won't work with the 6.4 version. Is the guy who made that one making one that will work with 6.4? Mark
Mark Hollingsworth |
Re: Deep Sleep and 6.4
not to hijack this thread, but on a somewhat related note, does the deep sleep bug only exist with the dig001? i've been considering an upgrade to the digi002 and am wondering if that will fix the deep sleep bug.
thanks, danl |
Are you talking about DigiSleep at xmidi.com? I'm the author of DigiSleep. I haven't upgraded to 6.4, so I wasn't aware that this version broke DigiSleep. I will take a look at it.
On a side note, I had read that Digi had worked out the deep sleep issue with 6.4. Is this not the case? And Yes, I believe this only affects PCI based Digi hardware (i.e. Digi-001) I'll take a look at DigiSleep to get it updated. Thanks for the update. |
hi birdFEEDER, thanks for the great little app. DigiSleep, it works fine for me, didn't break with 6.4.
for info: 10.3.3, 6.4, 733DA, Radeon8500, 001, 1GB
i7 Mini, 002R, OSX10.7.4, PT10 |
I am using the little app called PT Swtich (at least I think that is the name).
It unloads PT so it will deep sleep. A restart it required to run PT reliably, but I would do that anyway. I'll go check the website you mentioned, but is it a different than the one I"m using? Mark
Guys, how can it (digi sleep) be working!?
The old digi.kext files wher under OSX/Library/Extensions, and now tI don'tknow ewhere they are.... Digi sleep can't find em and bring an error message. (caus theyre not where they where in the old version.)
AMT |
didn't even know this app existed until this post!
just dowloaded it, and it works fine for me with a 001, 6.4 and Panther. its nice to hear those fans run down without having to shutdown. thanks birdFEEDER 001, 6.4; 733 Quicksilver (1.4Ghz OWC); 10.3.3 |
What error message are you seeing? Some generic message or something specific (my error message is pretty wordy)? Also, what is your system setup? Is your Digi device an 001 or Firewire based? I'm note really sure the Firewire based devices suffer from the deep sleep issue, anyone confirm this for me? Thanks, birdFEEDER |
Thanks
Scott Sheppard Executive Producer Host - Broadcast Radio The Inside Mac Show http://www.insidemacradio.com |
Thanks for checking... -bF |
Workaround for Digi001 & Deep Sleep | cleft | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-20-2005 01:53 PM |
Thank you for fixing CoreAudio and Deep Sleep!!!! | Muxlow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-20-2004 10:27 AM |
PT 6 breaks Mac OS X "deep sleep" | wcody | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 71 | 05-20-2003 09:38 AM |
No deep sleep-No shut down?? | kbahjat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-24-2003 11:28 AM |
G4 (AGP) Deep Sleep Compatibility | piscine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-11-2000 02:56 AM |
