#201
Just wondering...As of now, what Slate Plugins are deterring work flow because of CPU usage?
Aside from FG-X, of which there should only be a maximum of one instance, if that, in any session, what Slate plugins are CPU hogs? I can run way more instances of VMR/VTM/VBC than I'd ever need on my i7 2.7. Seriously, I have VMR/VTM on every track and VBC on most buses on crowded rock mixes and my CPU is rarely above 25% with that setup (that's counting other plugins involved as well! Lotsa Equilibrium, Kush Pusher/Clairphonic, Massey, Valhalla, etc..) I just don't see the real need for AAX-DSP at all here...Maybe I'm missing something, aside from the age-old "more dsp is better cuz more is better" argument? |
#202
Tracking with plugins on, latency etc on big full mixes
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
#203
How many tracks are we talking about? 50+?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#204
If I want to use his plugins on a track in real time, it will add an unexceptable amount to track with. So since this is a plugin that most people want on almost every track, it basically shuts you down from tracking with it in real time. Or... If you are mixing with it and want to use any DSP, then your DSP is inefficient if you go DSP to Native. It eats extra voices and adds extra latency. So this is a real pita if you want his plugin as the last plugin on any of your tracks. It basically eats your lunch on a DSP system-- especially being plugins that are advertised as being put on every single track and bus.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
#205
Exactly true!!!
Raoul Crane
#206
For me - I track vocals against premixed stems (which have used Native AAX plugs) to be good enough for a headphone mix. I then only use AAX-DSP plugs for the vocal path. I have around 100 sample system delay at that point, and the vocalists are happy. Contrast to a mix/master session where I routinely blow past the 16383 sample buffer. Mixing is another beast - and of course you want to have the latest plugs to achieve your vision of sonics. UAD is the worst offender for a HDX system, but in general any plugs delay you have on a track gets added to the delays on SubMix Groups and Master Inserts. Native plugs on SubGroups and Masters are excruciating. When I started the thread, the reason I decided to go HDX was the promise Steven made to support the platform. While I'm getting by, Slate, Kush and UAD are my BIG THREE usage counts in the plug department. The more that made the trek to support AAX-DSP, the better. Ask anyone with large mix sessions and high plug count (and this is not meant to open a debate on mix preference - that's a personal choice - sometimes characterized by More if Better by those with differing needs and goals) the value they place on having AAX-DSP plug availability. It is much better than 18 months ago, and I do not have any unused HDX DSP processors ... but I would buy another HDX card if Slate & Kush could provide AAX-DSP plugs to be used on the SubGroup and Master busses. Thank god for PlugIn Alliance, DMG Audio, Sonnox and SofTube!
T- ----- Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3 DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc Microphones: Telefunken, Neumann, Shure, AKG |
#207
+1000 for AAX DSP.
Can we have some update on this please M. Slate? |
#208
The only plugins I use that add latency these days are Kush's Pusher and Slate's VTM; both of which I simply disable on all tracks if I need to track during/after mixing (easy to do if you make sure to put all instances on the same insert slot!) Delay Compensation is always off here. Between 30-40, with 10 or so buses and a loaded master is normal for me. Last edited by AlexLakis; 05-25-2015 at 11:36 AM. |
#209
Steven Slate 5 months ago. Maybe he's changed his mind:
#210
Unfortunately I can not run my system at 64 buffer and I have the same computer... too many virtual instrument things going on as well as hungry native reverbs. I would love to see AAX DSP slate plugs... not about CPU usage, all about latency.
Slate digital vtm | JLC | AAX Plug-ins | 8 | 01-20-2014 09:03 AM |
Tracking with Slate Digital VCC | Rosco1969 | macOS | 3 | 01-05-2014 04:14 AM |
Slate Digital And UAD Where Are You ??? | kimballob | AAX Plug-ins | 11 | 11-23-2013 10:41 PM |
Slate Digital and Steven Slate Drums AAX | DHL | AAX Plug-ins | 6 | 04-22-2013 12:50 PM |
slate digital VCC | appledude | General Discussion | 5 | 12-03-2011 07:07 PM |
